ᐅ Are there alternative color options available for IKEA Brimnes furniture?
Created on: 29 Jul 2023 08:37
V
vinpraHello everyone,
I am considering purchasing some furniture from the IKEA Brimnes series but am wondering if there are alternative color options available for these pieces. I understand that Brimnes is usually offered in white and black-brown, but I am looking for other shades or finishes to create a more personalized look.
Are there any alternative color variations or special editions from IKEA itself or third-party suppliers that are less well known? Or are there proven methods to permanently and professionally change the color of Brimnes furniture using specific paints, veneers, or DIY techniques?
I look forward to serious, well-informed responses and experiences on this topic. Thank you!
The Brimnes series from IKEA is officially offered only in the well-known color options white and black-brown. IKEA typically produces durable surfaces, which is why alternative colors are currently not available directly from the manufacturer.
There are no officially certified color variations from third-party providers. However, it is possible to use professional furniture wraps or high-quality paint finishes, although it should be noted that the surfaces of Brimnes are not ideally suited for all types of coatings.
This is especially true for the paint on particleboard, which may be limited in terms of wrapping or painting due to surfaces that are too thin or too smooth. Even when using appropriate products, it is important to choose high-quality materials that will not peel or discolor.
In short: alternative color options are mostly DIY solutions using special films or paints, but they are neither official nor offered by IKEA.
vinpra schrieb:
Are there alternative color variations or special editions from IKEA itself or third-party providers that are less well-known?
Hello vinpra,
I understand your request well, as the standard colors of Brimnes are quite limited, and not everyone wants to keep their furniture so neutral.
If you plan to change the color of the furniture yourself, I recommend the following options:
- Furniture vinyl wraps in matte or glossy finishes: These wraps can be applied quite well with some patience and removed again if desired. Make sure to use accurately cut patterns.
- Painting with special furniture paint: Sand thoroughly beforehand and use a suitable primer to ensure the surface accepts the paint properly.
- Applying decorative paper or wallpaper as a creative alternative.
Just be aware that altering the original surfaces will void IKEA’s warranty, and durability can no longer be guaranteed. It’s worth testing first on a small area.
If you don’t have experience with repainting, I also recommend seeking professional help. Sanding and painting on chipboard or MDF surfaces require some skill to achieve satisfactory results.
I hope this helps!
vinpra schrieb:
I am aware that Brimnes is usually offered in white and black-brown, but I am looking for other shades or finishes to create a more personalized look.
I hope this helps!
