ᐅ Are there already fire-resistant solutions available for KALLAX units in basements?
Created on: 21 Jan 2023 19:23
reodi55
reodi55
21 Jan 2023 19:23
I am currently looking into whether there are any practical fire-resistant solutions specifically designed for the popular IKEA KALLAX shelving unit for use in basements. I understand that KALLAX is made of MDF panels, which naturally are not fire-resistant, and since basements often contain heating systems, electrical panels, or other potential fire hazards, I want to enhance safety.
Does anyone know of specific products or methods to protect KALLAX modules so that, in the event of a fire in the basement, the shelf itself (or at least its contents) is largely protected from fire? I am interested in professional fireproof covers, special coatings, or retrofit measures that can significantly improve KALLAX’s fire resistance.
Any advice on fire safety requirements in basements in general, especially concerning furniture, would also be appreciated. I do not want to rely solely on fire-resistant ceilings or the building structure but aim to secure pieces of furniture that store a lot directly.
Looking forward to any experience, solutions, or scientifically based approaches.
Thank you!
todunar
21 Jan 2023 20:07
Hey reodi55,
that’s a really interesting and important question you’ve raised! 🙂 I’ve actually tried a few approaches already, and I can tell you—there are some pretty effective ways to make the KALLAX more fire-resistant!
For example, there are special fire-retardant sprays that you can apply directly to the surface of the MDF panel. While they don’t completely prevent burning, they significantly slow down ignition. Especially if you have important documents or materials stored on the shelf, this can make a difference. Additionally, there are fireproof covers available—essentially heat-resistant sleeves that you can wrap around the shelf like a bag. They aren’t cheap, but they’re great for protecting against heat and sparks.
One important tip: make sure these products are approved for indoor use and residential fire protection, as not all of them are guaranteed for that!
I would recommend experimenting boldly, but not relying solely on one product. Multiple layers of protection offer better safety—fireproof mats, sprays, and good ventilation in the basement together form a strong combination.
Hope this helps you get started! And if you like, I can gladly recommend some manufacturers.
Deandre
22 Jan 2023 07:56
todunar schrieb:
Just an important tip: Make sure to check whether these products are certified for indoor use and residential fire safety – that is not guaranteed for all!
This is a very important note! Additionally, I would like to explain some basics relevant to fire protection for furniture, as this topic is often misunderstood.
MDF panels like those used in KALLAX are naturally combustible, since they are wood-based materials. Complete fire safety cannot be achieved by a single measure alone. There are special fire-retardant treatments (mostly phosphate- or ammonium-based) that reduce flammability and slow down the burning rate. However, these treatments are usually not water-resistant and lose their effectiveness over time, especially if the furniture is located in areas prone to moisture, such as basements.
As an alternative, there are fire-resistant claddings or cover panels (for example, gypsum boards with fire protection rating class A1, applied seamlessly with mortar on the side surfaces) that can be built around the KALLAX system. This method is somewhat more complex but very effective.
It is also important to note that combining these measures with structural fire protection in the basement—such as automatic smoke detectors, fire and smoke doors, and fireproofing of electrical installations—is part of a comprehensive approach. Furniture alone can only offer limited protection.
I am happy to provide more detailed advice on which standards and protection classes should be checked if desired.
FeAndreas1
23 Jan 2023 10:31
reodi55 schrieb:
Does anyone know of specific products or methods to protect KALLAX units so that in the event of a fire in the basement, the shelf itself (or at least its contents) is largely fire-resistant?
This question is quite complex. I will focus on the physical and technical aspects of fire resistance in the context of typical KALLAX materials and basement conditions:
1. KALLAX is made of particleboard or MDF panels, which are flammable. Without protective measures, they ignite at around 280-320°C (self-ignition temperature of wood-based materials). This can happen quickly in a fire.
2. Fire-resistant solutions that actually provide lasting protection usually rely on coatings with intumescent materials. These expand when exposed to fire and form a heat-resistant crust that insulates the underlying materials. Such coatings are usually designed for walls or ceilings but can also be applied to furniture in DIY projects.
3. Alternatively, fireproof enclosures can be used – for example, fire-resistant sandbags (impractical), fire-resistant insulation boards (mineral wool, calcium silicate) with special coverings.
4. For basements, it is also important to regularly inspect fire protection measures. Coatings and coverings age and lose effectiveness over time.
5. Practical advice:
- Fully enclosing a KALLAX unit in fire-retardant material, such as a drywall wall made from gypsum fiberboard panels with fire rating A2, would be ideal.
- Access to the unit must not be compromised.
However, I would like to turn the question back to reodi55: What risk level do you estimate for your basement, and what fire resistance duration are you aiming for? There are significant differences between short-term fires and prolonged heat exposure, which strongly influence the choice of solution.
Without this information, giving recommendations is difficult because “fireproof” is not a generic term but must always be defined in terms of time and temperature.
