ᐅ Affordable landscaping for a new build – what is the best approach?
Created on: 9 Apr 2022 11:16
MarkoW.
Good morning everyone,
As some of you may have heard, we are building a semi-detached house as a prefabricated home. As is common with most suppliers, the exterior landscaping is not included in the price. So, we have to take care of that ourselves.
I have read up extensively on the topic but unfortunately keep finding very conflicting prices and cost estimates.
Just a few days ago, there was a thread where someone wanted to spend six figures on their garden—I nearly fell off my chair.
So, about our garden: The area behind the house is roughly 230 square meters (2,476 square feet), a bit over 10 meters (33 feet) wide and just over 20 meters (66 feet) long. We plan to build a simple paved terrace, which will probably be slightly higher than the rest of the garden later on. The house (being timber frame construction) has to be elevated 30cm (12 inches) above ground level. Since we want level access to the terrace from the house, it will be built flush with the door, and the lawn will then be slightly lower. We will also need to install drainage between the terrace and the house to prevent water from running into the building. That shouldn’t be a problem because the rainwater downpipes’ drainage also runs in that area. According to online sources, paving the terrace costs around 100 euros per square meter (approximately $100 per 10.8 square feet).
Regarding the fence, we will of course coordinate with our future neighbors. We’re considering separating the terrace from the neighbor with gabion walls (about 4 meters / 13 feet long). The rest of the garden will be enclosed with a welded wire fence (please no debate about the fence type—the development plan requires hedges, chain-link fencing, or welded wire fencing). On various websites, I calculated prices for this. About 50 meters (164 feet) of fencing (1.8 meters / 6 feet high and 2 meters / 6.5 feet wide per panel), including posts, costs around 4,000 euros. Privacy screening strips might be added, but they can be easily installed by ourselves, so I am leaving those out for now (around 700 euros).
We also want a lawn. I think rolled turf looks best, though I’ve also read about very different prices here. When searching for prices, about 10 euros per square meter (approximately $10 per 10.8 square feet) is displayed. Alternatively, we could sow grass seed ourselves, but then there is the risk that birds will eat it.
No flowers, trees, or shrubs are initially planned. To the right of the house, we want a garage (we have quotes starting at 15,000 euros for an 8 x 3 meter (26 x 10 feet) prefabricated garage with electricity, foundation, and installation).
The driveway / front garden can only be done once the construction access road is removed.
So what makes the garden so expensive? I’ve estimated my calculated costs:
Terrace: 40 sqm x 100 euros = 4,000 euros (possibly a bit more if more base material is needed)
Rolled turf: 200 sqm x 10 euros = 2,000 euros
Fence: 4,000 euros
That brings the total to about 10,000 euros (with the terrace costs including labor).
Then there is additional labor for the fence and lawn installation (unfortunately, I don’t feel confident doing this myself, and none of my acquaintances can either). Is labor really the main factor driving the cost so high? What labor costs would you estimate for these jobs?
Also, does it make sense to install the garage only after completing the garden work? Otherwise, it would be difficult to bring in excavators and other machinery.
What other tips would you have for keeping the garden as affordable as possible?
By the way, the plot used to be farmland, so it’s flat and the soil should be good for this kind of work.
Fence: 4,000 euros
Phew, I really stirred things up with this thread 🙂
First of all, thank you very much for all the input I have received from you. You are probably right, and you “grow into it” once you are living in the house and have enough time to focus on the garden and so on. Right now would actually be perfect weather for that, but unfortunately, we still live in our rental apartment…
The tip about the books was also good; I’ll have a look at them sometime soon 😉 And how the garden will be enclosed will also only become clear after moving in (and in consultation with the new neighbors).
Caudaequina25 Mar 2023 15:43driver55 schrieb:
He wants to save money though…
(I once ordered samples, 15x15 cm (6x6 inches)…€40 per square meter (about $37 per square foot)).
The real question is how much budget is actually “left,” how the garden/outdoor areas are supposed to be designed, and what he wants or is able to do himself.
By the way: for €4,000 there’s no way to get 50 meters (55 yards) of double-wire mesh fencing, not even just the materials. (Unless everything is crooked and uneven right from delivery and starts rusting after two years…) €7,300 – Double-wire mesh fence 1.20 m (4 feet) high with post caps, 138 meters (151 yards) – Poland makes it possible
Georgian2019 schrieb:
We seeded about 500 square meters (5,400 square feet) of lawn, costing around 200 €. Nothing was eaten away, and hardly any reseeding was needed. Duration: 5 weeks with watering several times a day.
Otherwise, doing a lot yourself or with friends/neighbors saves the most.
I need to bump this old thread in the hope that Georgian is still reading here.
Can you or anyone tell me what kind of facade paint this is?
