ᐅ Bathroom layout with sloped ceiling in the attic
Created on: 31 Oct 2024 17:06
magdalena789
we are planning to create a bedroom and a bathroom in our attic.
In terms of space, the bathroom doesn’t offer many options, so we are considering placing the sink, radiator, and bathtub in a single line. However, the toilet is relatively narrow in width, which hopefully won’t be an issue for us.
Each square in the layout represents 10cm (4 inches), with dimensions rounded up or down to the nearest 5cm (2 inches).
Thanks for your feedback
hanghaus2023
1 Nov 2024 21:52
kbt09 schrieb:
@hanghaus2023 You placed the roof window in the bathroom area randomly, right?
No. It’s exactly where I want it. It’s usually less expensive if you only build the new part.
The original poster should specify exactly what kind of window will be installed there. Then it can be drawn in properly.
1 Nov 2024 23:54
magdalena789 schrieb:
The current small roof window will be removed and replaced with one the same size as on the other side.
Try drawing that in. It will then also be positioned a bit higher than where the insulation is.
We were able to take over the sliding wardrobe from my mother. It was very expensive, and we thought of using it as a room divider.
Is it now placed in front of the window?
If only two of you use the bathroom upstairs, then open up the entire space. Use the wardrobe as a room divider as planned, partially separate off the toilet, and position the sink and shower more towards the center of the room—arranged so that everything fits well and is easy to use.
kbt09
2 Nov 2024 00:37
It is still important to consider the location of the connection point for the drainage. This must fit accordingly.
Is screed still going to be applied there? Or what is the floor structure? Well, as mentioned, a more detailed plan with elevation lines, etc., is needed.
hanghaus2023
2 Nov 2024 09:59
Try sketching it out. The height there is a bit higher than where the insulation is.
Is it located in front of the window now?
If only two of you use the bathroom up there, then open up the whole space, use the cabinet as a room divider as planned, partially separate the toilet area, and move the washbasin and shower more into the room so everything fits well and is practical to use.
The original poster (OP) is quite brief in the discussion.
At least the OP has drawn the cabinet there.
In my opinion, turning it into a large room is not a good idea. The bathroom should be around 22°C (72°F), while the bedroom should be cooler.
Will the OP respond again?
hanghaus2023
2 Nov 2024 10:06
Somehow, my section and part of the text got lost.
Schematic side view of a house with a pitched roof, interior walls, and windows.
hanghaus2023
2 Nov 2024 10:13
kbt09 schrieb:
@hanghaus2023 You placed the roof window in the bathroom area randomly — or was there a reason?
No. More like where I would prefer it.
Removing the old one would just cost unnecessary money.
To the original poster: what kind of window exactly and where should it go? A 1m (3.3 ft) wide window can be done by replacing a rafter.
But maybe it’s also possible with the existing window in the gable? The wardrobe can’t be placed in front of the window anyway. The roof window is in the sleeping area.
Side cross-section view of a house with a gable roof, interior walls, door opening, and window.
