ᐅ Offer for Double Garage 6x9 m / Foundation and Ground Slab
Created on: 12 Mar 2023 05:19
Peppoderwilde
We requested two quotes from our construction company:
  • Construction of a solid masonry double garage 6x9 m (6x9 meters) as part of building our single-family house
  • Construction of a reinforced concrete garage slab 6x9 m (6x9 meters) (preparation for double garage) as part of building our single-family house
1st Quote
Masonry garage 6.00 x 9.00 m (6.00 x 9.00 meters), including a storage room as part of the residential building work, founded on strip foundations (without gravel filling work, assuming a gravel base provided by the client), the concrete slab will be finished with a rough trowel surface, masonry made of hollow bricks, thickness 17.5 cm (7 inches), exterior facade finished with white plaster, visible wooden beam ceiling, flat roof waterproofing, one sectional door, insulated, size 5.00 m x 2.135 m (5.00 x 2.135 meters), surface woodgrain, M-rib design, color RAL 7016 anthracite gray, with electric drive (electrical connection provided by client) and two remote controls, one side entrance door valued at €2,000.00 gross including 19% VAT, including structural engineering and execution drawings
Additional cost: €47,000.00 gross including 19% VAT
Alternative: Additional cost for interior plaster: €2,900.00 gross including 19% VAT
Alternative: Additional cost for cement screed: €2,510.00 gross including 19% VAT
Alternative: Additional cost for ceiling cladding made of gypsum fibreboards: €2,780.00 gross including 19% VAT
2nd Quote
Reinforced concrete garage slab thickness 20 cm (8 inches) for garage dimensions 6.00 x 9.00 m (6.00 x 9.00 meters) as part of the shell construction of the residential building, founded on strip foundations (without gravel filling work, assuming a gravel base provided by the client), concrete slab finished with a rough trowel surface, including structural engineering and execution drawings
Additional cost: €12,860.00 gross including 19% VAT
I am a layperson and naturally find it difficult to assess the offers. There are surely experts here who can provide an evaluation. 🙂
11ant12 Mar 2023 19:09
dimba234 schrieb:
In the end, we will probably go with a different general contractor, partly because the garage is relatively expensive. But turnkey construction has a very good reputation in our area (friends, relatives, coworkers all consistently say so).
dimba234 schrieb:
No... builds in the Dortmund area and the districts of Paderborn / Soest. We are from the Soest district. We will likely choose a company from Bad Wünnenberg-Leiberg. However, we plan to build a house with a garage. I’m not sure if they offer just the garage. Their focus is on single-family homes.
If the provider is good otherwise, it’s better to source the garage from someone else than to change the general contractor because of the garage price. I can also highly recommend Hoffmann for garages. Company names can be mentioned here, but only negative experiences belong in a moderated section called “Experiences with …”.
dimba234
12 Mar 2023 21:59
If the supplier is otherwise good, it’s better to choose a garage from someone else than to change the main contractor just because of the garage price. I can also highly recommend Hoffmann for the garage. Company names can be mentioned here, but only negative experiences should be shared in a moderated section called "Experiences with ...".
I followed your recommendation immediately and also requested an offer from Hoffmann. Thank you!
The dilemma is that the second main contractor also does a good job. I haven’t received direct feedback, only "friends of friends have built with them and are satisfied...". But our personal impression regarding advice, planning, and transparency tends to support the second provider. To stay on topic, here is our garage offer:
14 Plastered Garage
Garage measuring 6.00 m * 9.00 m (19.7 ft * 29.5 ft), partly attached to the house.
The exterior walls are built with 17.5 cm (7 inch) hollow clay bricks. The front, boundary, and rear walls will be plastered. Interior walls are plastered (excluding painting). Included basic electrical installation (1 switch, 2 outlets, 1 ceiling fixture). Equipped with a Hörmann sectional garage door with M-profile, door with window insert, and 1 window. Cement screed on separating layer. The baseboard inside the garage will be painted approximately 10 cm (4 inch) high. The joint between screed and wall will be sealed with permanent elastic sealant. The roof (sloped for rainwater runoff) will be constructed with wooden beams and waterproofing. The underside of the roof will be covered with drywall. The roof will be connected to the rainwater drain system via a flat roof drain. The garage will have a continuous slate band around it.
40,850.00
11ant12 Mar 2023 23:37
dimba234 schrieb:
The dilemma is that the second general contractor also does a good job. I didn’t get direct feedback here, just "friends of friends have built with them and are satisfied...". But our personal impression regarding consultation, planning, and transparency also leaned toward the second provider.
If both are not only from the region but also primarily serve clients there, I would visit customer houses from both and take notes: once for the objective impression as a kind of grade, and once to categorize these customers into three classes. Class A includes people with a similar mindset to ours and comparable income levels, while classes B and C include people where instead of "and" there is an "or". Then I would calculate the average grade of my impressions separately for classes A, B, and C. Impressions from houses where the customers essentially belong to class D (meaning there is no overlap with them in attitude or social background) I would disregard. If, after this, both general contractors are still "tied" and you want to leave the decision to chance by flipping a coin, then enjoy this fortunate situation.
14 Garage plastered [...] [B]40,850.00[/B]
If a provider who otherwise offers a reasonable price-performance ratio has an "outlier" on an optional side item, I don’t interpret that negatively as if they were overcharging or unable to calculate, but quite the opposite: it is a diplomatic signal that they only want to serve the client within their core expertise. The less favored side business is deliberately priced with a markup that gives the client a clear argument to exclude this item from the contract. As a customer facing a decision, you should then ask general contractor "Y" to remove this item from the package just as contractor "X" has done. Under no circumstances should you "compare apples with oranges" or "adjust totals" by wrongly comparing total prices from contractor "Y" including the favored garage and "X" including the less favored garage as if they were equal. This is an excellent opportunity to let your impression prevail over pure number crunching. Building a house requires a wise investor.
Peppoderwilde
13 Mar 2023 09:05
dimba234 schrieb:
14 Plastered Garage
Garage measuring 6.00 m * 9.00 m (19.7 ft * 29.5 ft), partially attached to the house.
The exterior walls are built using 17.5 cm (7 inches) hollow bricks. The front, boundary, and rear sides are plastered. The interior walls are also plastered (without painting). Basic electrical installation included (1 switch, 2 outlets, 1 ceiling fixture). Equipped with Hörmann sectional garage door with M-profile, door with window, and 1 additional window. Cement screed on separation layer. The garage baseboard is painted approximately 10 cm (4 inches) high. The joint between screed and wall is sealed with permanently elastic sealant. The roof (sloped for rainwater drainage) is constructed with wooden beams and waterproofing. The ceiling is covered with drywall panels. The roof drainage connects to the rainwater sewer via a flat roof drain. The garage features a continuous slate strip around the perimeter.
40,850.00
Is the garage foundation included in your offer?
dimba234
13 Mar 2023 23:45
Peppoderwilde schrieb:
Is the garage foundation included in your quote?
The foundation is included. However, I make sure it is explicitly stated in the quote.
Kati2022
16 Mar 2023 16:26
Hm, I would like to know how much I would have to pay for our garage (6 x 8.5 meters (20 x 28 feet)) if contracted separately...
Our shell construction contractor included the garage in the house quotation. House with:
- 175 m² (1,884 ft²) of living space,
- masonry with filled Poroton bricks,
- strip foundations insulated on both sides,
- 12 cm (5 inches) XPS insulation under the slab,
- complete groundwork (excavation about 120 m³ (4,237 ft³) + almost 400 t of gravel had to be filled),
- drainage, 2 access shafts,
cost a total of 195,000 (local currency) in the final invoice.
Based on the prices I see here, this would mean the garage accounts for about one-fifth of the house price. Quite surprising...
Additional costs for the shell garage were:
- concrete ceiling waterproofing – 4,500 (local currency),
- secondary entrance door – 1,000 (local currency),
- garage door – 3,000 (local currency).
Plastering and screed were also included together in the house quotation. I estimate both together at about 3,000 (local currency).
