ᐅ Planning a 12 sqm Bathroom Efficiently
Created on: 25 Jul 2020 10:38
E
Enoibib
attached is the floor plan of the master bathroom.
Access is intentionally only through the walk-in closet, which is located to the left of the bathroom. Because of the children's bathroom, the master bathroom in the lower left corner is practically unusable. The bathtub is currently planned as a corner tub (this is not yet clear from the plan).
My issue is the following: I would like a walk-in shower without a door, since we will be living in an area with hard water and cleaning is not our favorite task. In my opinion, the wall between the toilet and the shower would need to be 1.40 m (4 feet 7 inches) long to prevent excessive water splashing. However, that leaves very little space for the bathtub. In my view, a T- or L-shaped layout is not possible because the bathroom is too small.
Would it be wiser to keep the wall between the toilet and shower at 1.20 m (3 feet 11 inches) and instead install a glass door for the shower?
Do you perhaps have ideas or suggestions for a different layout? Or is this already the most practical solution?
Best regards.
Grundriss: Flur mit zwei Bädern (Eltern- und Kinderbad) und Sanitäranlagen.
Pinky030127 Jul 2020 20:05
Is a door from the bedroom to the hallway necessary? I would only make it accessible through the walk-in closet, which would also provide some additional sound insulation.
E
Enoibib
27 Jul 2020 23:25
Pinky0301 schrieb:
Is it necessary to have a door from the bedroom to the hallway? I would only make it accessible through the walk-in closet, which also provides some sound insulation.
True, good idea, I'll think about that again!
E
Enoibib
28 Jul 2020 14:57
Does anyone else have any ideas?
Perhaps the master bathroom and the children's bathroom could be rearranged in some way. The important thing is that the children's bathroom is accessible from the hallway, and the master bathroom is accessible from the walk-in closet.
Alessandro
28 Jul 2020 15:30
I would go with one of these options. Although the toilet is positioned within the room, you can’t afford to sacrifice any space from the walk-in closet by moving the door.
Grundriss eines Badezimmer-Layouts mit Elternbad und Kinderbad, Badewanne und Toilette
Grundrissplan: Zwei Badezimmer (Eltern/Kind) mit Badewanne, Toilette, Waschbecken, Heizkörper.
kbt09
28 Jul 2020 15:32
Alessandro schrieb:
however, you can’t afford to lose space in the walk-in closet by moving the door
Unfortunately, that was also my thought when I saw the overall floor plan.
Pinky030128 Jul 2020 15:35
Yes, the door should stay as it is. I don’t think the original floor plan is bad. I’m just not very fond of the corner bathtub; wouldn’t a regular bathtub fit there as well?
