This is the construction report following an earlier thread on floor plan design.
Planned are:
618 m² (6650 sq ft) plot of land
150 m² (1615 sq ft) living space
50 m² (540 sq ft) double garage
Air-to-water heat pump with underfloor and wall heating
Zehnder ventilation system
Exterior blinds in the living room, kitchen, and gallery. Windows anthracite on both inside and outside
Smart home wireless Homematic IP
Planned budget: €300,000 including land and ancillary costs + €30,000 reserve
Plus €12,500 net for a 9.6 kWp photovoltaic system financed separately
Only small regional companies recommended by other builders are being considered.
So far, the following trades have been contracted:
Earthworks: €20,000
Shell construction: €73,000 + €1,000 for the porch above the front door, Wienerberger Poroton T9
Roof: €19,000 + €1,500 scaffolding
Electrical work: €11,000 excluding chiseling work
Window materials: 17 Salamander triple-glazed units + Beck & Heun roller shutters + 5 Selt exterior blinds = €16,000
Quotes received for:
Plastering without decorative finish: €21,000
Bathroom ceramics Villeroy & Boch: €3,000 from Reuter Bathroom Shop
Interior doors Herholz: €2,600
Hörmann front door + garage door: €3,000
Building services materials from the internet: €10,000
Zehnder ventilation unit ComfoAir Q350 TR enthalpy heat exchanger including materials: €4,000 from Selfio
Nobilia kitchen furniture: €5,500, Bosch Series 4 kitchen appliances from Für Uns Shop with 50% discount for €3,500
Planned are:
Earthworks: €20,000
Where exactly is there a flow of 49 m³/h (29 cfm) in a pipe?
The calculation is by Helios.
As with any trade, you should approach things with common sense and understanding. A deviation of 3.3 percent is acceptable. Or do you notice any difference in your house between an air exchange rate of 0.34 and 0.35?
Hello
From posts 46, 47, and 48, it can be understood that only one pipe is planned per room. I’m sure I am not the only one who interpreted it this way.
With installation and proper balancing of the valves according to the above, using the corresponding number of pipes, which I initially also overlooked, everything should then work correctly.
hegi___ schrieb:
And before anyone notices,... according to the plans, the rooms have either supply or exhaust ventilation only. So, now I have complained a bit in one of your threads.https://www.instagram.com/11antgmxde/
... according to the plans, the rooms each have either supply or exhaust air only. So, now I have "complained" about this in one of your threads What do you mean by that?
hegi___ schrieb:
What do you mean by that?Well, you said in post #33,hegi___ schrieb:
He always tends to complain a lot in my threads.https://www.instagram.com/11antgmxde/
