Created on: 27 May 2019 10:48
goalkeeper
Golfi90 schrieb:
Unfortunately, yes...
Especially when you want to use a lot of indirect lighting on walls, etc., it looks really unpleasant.
We’re biting the bullet and leaving it as is for now. We need to move.
But there are definitely people for whom this isn’t such a big deal. And for them, the result can be satisfactory. Do you mean direct, focused light that shines like a spotlight along the wall?!
Indirect light should be diffuse and not highlight any surface irregularities.
goalkeeper schrieb:
What do you think about the arrangement of the ceiling spots in the master bathroom? That should be enough, right? goalkeeper schrieb:
We will now install four in the bathroom — we don’t really want floodlights. I would go with four, placed on the ceiling forming a rectangle or square.
And make them dimmable... Electricians usually avoid installing LEDs, and it’s easier to dim halogen lights well.
The bathroom mirror should have a separate switch.
goalkeeper29 Mar 2020 09:45ypg schrieb:
I would go with 4 and arrange them on the ceiling in a rectangle or square.
Then make them dimmable… Electricians are usually reluctant to install LEDs, and halogen lights are better for dimming.
The bathroom mirror light should be switchable separately. The spotlights are self-installed and can be chosen freely. We will definitely use LEDs.
We will stick with three and add a switchable mirror light – that was planned anyway.
Always prefer replaceable bulbs with LEDs.
LEDs can fail too. If one of the three spotlights breaks, you will need to replace it and might not get an identical one. This means if one breaks, either replace them all or accept a less appealing look because different models must be mixed.
AlbertKamika29 Mar 2020 15:07Could you please share the floor plans of the entire house again or let me know where I can find them? Thanks!
goalkeeper29 Mar 2020 15:21AlbertKamika schrieb:
Could you please share your complete house floor plans again or tell me where I can find them? Thanks!Sent a private message.
goalkeeper29 Mar 2020 15:28
