ᐅ Bathroom Layout Suggestions / Tips for 15 m²
Created on: 28 Jun 2019 16:10
O
overseer
I will soon be building a house. The planning with the architect is already complete, meaning the floor plan is final, and the doors and windows are fixed. Now I have a relatively well-shaped large bathroom and have been thinking for a while about how to best arrange the shower, bathtub, and toilet. The layout suggestion on the floor plan feels somewhat unconsidered. Basically, I like a "T" or "L" arrangement, but I have trouble visualizing it, which is why I am turning to you.
Requirements:
Walk-in shower, about waist-high masonry wall with glass above. Shower with a door that can be closed. Not too narrow, not too wide. Maybe about 120cm x 120cm (47 inches x 47 inches) maximum.
Bathtub along a wall. Large enough to comfortably fit people of average height.
The floor plan shows that the bathroom will have a sloped ceiling. However, since the bathroom is large enough, it wouldn’t be a problem to build a wall at the 2m (6 ft 7 in) line.
Best regards and thanks in advance!
Grundriss einer Etage: Schlafzimmer links, Bad, Diele, Treppe, zwei Kinderzimmer rechts.
Anitra
28 Jun 2019 21:38
If you do it deliberately like that, it works out fine.
haydee
28 Jun 2019 21:48
You have an open-plan kitchen and living area, right?
I can't imagine a T-shaped layout with the sloping ceilings. How is that supposed to fit in?
O
overseer
28 Jun 2019 22:30
Unfortunately, I have no idea how an L-shaped layout could fit here. I’m not very creative when it comes to room planning, which is why I started this thread. I’m looking for ideas. I also find it helpful and reassuring when people who are more experienced than I am can tell me what works and what doesn’t.
I understand that open-plan kitchens are a combination of the living area and kitchen, right? We have a kitchen with a dining area in the bay window. So, kitchen and dining room together. The living room is separate.
haydee
28 Jun 2019 22:48
Open-plan kitchen and dining area means cooking and eating in the same room.
I thought you had an L-shaped plan.
An L-shape works in square bathrooms without sloped ceilings. I don’t like it. I find it makes spacious rooms dark and feel smaller.
haydee
28 Jun 2019 22:57
I would do it as suggested by Kaho.
Or can the toilet and shower be swapped?
Be sure to take 11ant’s advice into account.
28 Jun 2019 23:03
overseer schrieb:
I have now also added the floor plan for the ground floor. I thought this was irrelevant for planning the bathroom.
I wish that were true. The drain of course runs through the ground floor, which is why it’s located on the exterior wall. But now take a look at what’s below: partly no longer interior living space, partly a living area with a window.
overseer schrieb:
Toilet next to the bathtub sounds good, thanks for the tip!
I’d say the toilet stays exactly where it is.
If you set up the shower as Katja suggests, it will be consistent with the rest of the house. Almost all entrances are planned the same way there.
