ᐅ Planning to build a house using the Gulf farmhouse style – garage integrated into the house
Created on: 2 Apr 2018 18:04
Avemaria87
After considering various building concepts for some time, we have realized that we prefer the Gulf house construction style.
Nowadays, most houses have the garage located in an extension or even in a separate building. Our dream would be to integrate the garage into the house itself and connect it directly to the utility rooms (laundry room, etc.), which in turn would flow into an open-plan kitchen and living area. Has anyone had experience with this or even built such a house? How feasible would this be?
Best regards!
2 Apr 2018 23:00
toxicmolotow schrieb:
I know what a Gulfstream is, but what exactly is a Gulfhouse construction method?
And what does a construction method have to do with design (isn’t it more about the latter?!?)
If even Google doesn’t provide clear and accurate results, something’s off...
And yes, your challenge will be meeting the energy efficiency requirements.
The garage can be outside the thermal envelope, but that also makes things more complicated...
Niedersachsen house: red brick, half-hipped roof, single-story. Cozy, with small windows, therefore relatively dark, and was very common as a farmhouse in the past.
Nowadays, calling this a “property with extensive farmstead” as the main house is basically the opposite of current trends.
Usually, people buy something like this as an existing building and spend about a decade renovating it. Not meant to sound negative—I had a similar dream once [emoji4]
Anyway: anything is possible. The garage can be built outside the thermal envelope, but it’s more expensive...
However, I doubt that an integrated garage really suits this house type.
I would rather see that garage as a separate outbuilding—typical for a property like this.
In my opinion, the house needs a large plot of land and a rural setting. If it doesn’t, it would be like placing a Bauhaus-style house on the beach in Sylt’s Kampen district. Something to keep in mind: there are certain houses you might appreciate but don’t necessarily want to build yourself. Often, local zoning plans / building permits (planning permission) make this decision for you.
Do you have a plot where this house would fit and is allowed? That would be interesting. Please keep me/us updated [emoji4]
toxicmolotof
3 Apr 2018 00:22
Sorry, I guess I picked up the English touch there. Now there are some hits as well.
Okay, tastes vary, and that has to be accepted, but how can you comfortably live in it if you still want to integrate the garage on the ground floor?
I could even imagine building a pure residential house like that and placing a smaller replica as a garage next to it at a right angle. That would even reflect the courtyard effect.
But with a garage, the already limited wall surface area in such a house gets even smaller.
11ant3 Apr 2018 21:48
Avemaria87 schrieb:
that we prefer the Gulf farmhouse construction style.
What exactly do you mean by that: generally the house concept of “everything under one roof,” or should the house specifically be a tribute to historical models?
When integrated into the house, the garage loses its privilege of being placed in the side setback area of the lot. This is probably the main reason why people prefer to have it separate or at least clearly recognizable as its own building section.
What is generally common also influences how plots of land are subdivided. In this respect, I see the main and most likely obstacle to this wish being that it may be harder to find suitable plots for it.
A single-unit house is also somewhat more cumbersome, whereas a separate garage can be arranged more flexibly within the building envelope.
Nordlys
3 Apr 2018 22:17
Just Google heban House 119. They have done a good job there, exactly what you want. These units come from Pl.
3 Apr 2018 22:59
@Avemaria87 is speechless with so much input.
Müllerin
3 Apr 2018 23:18
Nordlys schrieb:
Try googling Heban House 119. It’s a pretty good implementation of what you want. These units come from Pl.
I really like that, especially as a home for two people in later years...
