ᐅ Natural stone countertop
Created on: 12 Jan 2017 10:19
peter74
peter74
12 Jan 2017 10:19
Does anyone know where I can buy natural stone slabs in Berlin? There are sometimes large suppliers where you can buy "surplus stock." I am looking for a granite countertop.
DG
12 Jan 2017 11:42
Hello Peter,
a Google search for "granite surplus stock Berlin" provides some interesting links, but can you cut/work the granite yourself? The slabs might be trimmed (2–4mm (0.08–0.16 inches)), and if the leftover piece doesn’t happen to fit your kitchen exactly, you’ll need to adjust or cut it to size, especially if the stove and/or sink are to be inset.
Dirk Grafe
peter74
12 Jan 2017 12:06
Thank you for the advice and the quick response. I will do some more detailed research this evening... I have a friend with his own workshop, hopefully he has the right tools...
Regards, peter74
DG
12 Jan 2017 13:05
Granite can be cut with a wet saw, but for kitchen countertops, depending on their size and thickness, the weight quickly becomes too much to handle without a crane. The material must be properly supported during cutting to avoid breakage, so the machine needs to have an adequate support surface. This cannot be achieved with a tile cutter anymore, unless you are a hardcore DIY tinkerer.
Dirk Grafe
HERR_bau
12 Jan 2017 19:06
I would also generally advise against granite countertops; that was my first idea when planning our kitchen as well. However, just the installation alone (crane plus at least four people) is so complex that I quickly abandoned the idea. Looking ahead: in 20 years, you might want a different look for your kitchen, and then you’ll be dealing with a 600 kg (1,320 lb) slab... which can only be removed in sections and requires a lot of work.
And that’s not even considering your case of “I’ll just grab a leftover piece on a bargain and cut the slab myself quickly”... :-)
DG
12 Jan 2017 20:46
Granite is really great—I have it myself. It looks amazing, is virtually unbreakable, low maintenance, and you can even cut directly on the countertop. The only downside in my opinion is the weight. But we managed to install it without a crane, although it was really challenging for four people. They definitely struggled quite a bit. 😉
You can also remove it completely after 20 years if you want, but you would need to find someone who wants the slab(s) with exactly the cutouts for the stove, sink, and drilled holes, and in the exact color with a few blemishes. That person would practically have to design their kitchen around these slabs... the chance of that is basically zero. So you can just break it and use the leftover pieces for some DIY projects.
That said, I expect the kitchen itself will be worn out by then, and you can bring the granite back to life with a good polishing.
But yeah, you can’t just quickly grab one from a clearance sale.
Dirk Grafe
