ᐅ Windows & Window Sizes: What to Choose? Double-Hung or Casement Windows?
Created on: 18 Apr 2018 15:07
Z
zizzi
for our bungalow, we have partially planned three windows measuring 138.5cm by 126cm (55 inches by 50 inches) in height, and one window 138.5cm by 76cm (55 inches by 30 inches) in height. Given this width, would it make sense to use double casement windows? Do such windows even exist?
Since we have not planned for a mechanical ventilation system, we will be ventilating frequently. With ventilation, relatively wide single casement windows will open fully into the room, which I find disruptive. Over time, this could also cause sagging due to the weight and long lever action. Additionally, if there is a flower vase or other items on the windowsill, they must be completely cleared away when ventilating. With double casement windows, on the other hand, you can simply slide one side open to the side.
Thanks for your advice
haydee
28 May 2018 10:13
Find the window size acceptable.
Use a faucet with a bayonet fitting.
In our case, the left window sash opens fully, and for cleaning the right one, I detach the faucet easily using the bayonet fitting. It’s a simple step.
11ant28 May 2018 18:08
blaupuma schrieb:
What size works well? Is there anyone here who thinks my double sash window is too large in hindsight? We are planning rather large double sash windows and are unsure if they might appear too big.
Are you really aiming to win first prize for odd questions here?
What would be the alternative if someone says two sashes are too big: a triple sash (which would only work with two sashes and a mullion, or would you have to go with folding sliding doors then)?
For single sash, I recommend up to 126cm (50 inches), for double sash from 151cm (59 inches) and up. What do we have here: 176cm (69 inches) or 188.5cm (74 inches)?
My advice for the kitchen faucet would probably be a blow to your symmetry dogma: use a fixed glass lower section here.
Z
zizzi
28 May 2018 20:05
I find a fixed glazed lower section more comfortable, but what about the appearance? I assume this is on the ground floor, so you can also clean it from the outside.
11ant28 May 2018 20:27
zizzi schrieb:
I assume that is on the ground floor, so you can also reach it from the outside for cleaning.
Yes, bungalow. Cleaning is fine, but of course, you don't want to ventilate only with the window slightly open...
Of course, using a removable handle works too (and is better / more convenient). I just find fixed lower parts like that practical in the kitchen for other uses: you can put small pots with chives or similar there.
Z
zizzi
28 May 2018 20:58
Yes, that is what I meant. Using a fixed base unit for the kitchen to allow ventilation and to serve as a windowsill is a better option.
