ᐅ Wide joints in aerated concrete blocks
Created on: 14 Nov 2016 13:29
deichwacht
deichwacht
14 Nov 2016 13:29
We are currently building a new house (KfW40 standard) with exterior walls made of aerated concrete blocks (17.5cm (7 inches)) that will later be clad with brick veneer after insulation is installed. In several places where cut aerated concrete blocks meet, relatively wide joints (about 1cm (0.4 inches)) have formed, which are still open at the moment. The site manager does not see this as a problem. The gaps are planned to be filled with mortar on the outside and sealed airtight on the inside by plastering.
Is the presence of such joints already considered a defect, or is this acceptable? Will the insulation be affected by these joints? Is the planned method of sealing proper, or should it be done differently?
Thank you very much!
Grosse Betonblockwand im Rohbau vor einem Wohnhaus, links steht ein weisses Auto.
Person hält Hausschlüssel vor einer Tür, Türspalt sichtbar
andimann14 Nov 2016 13:42
there will still be an external thermal insulation composite system (ETICS) applied, right? Then it’s not a problem. Structurally, it doesn’t really matter anyway.
What else could they do, cut a brick just for one centimeter?
Andreas
deichwacht
14 Nov 2016 13:51
Yes, there will be insulation made of expanded polystyrene (160mm (6.3 inches), WLG 032) applied. I do not expect 1cm (0.4 inch) thick panels. But isn’t it generally possible to cut the blocks to size?
andimann14 Nov 2016 13:53
You didn’t photograph the entire wall. Could the length of the wall be exactly X bricks plus 1 cm (0.4 inches) there?
Legurit
14 Nov 2016 13:54
Are there any guidelines for... insulating mortar might be an option if the width is outside the standard range (just assuming that without knowing for sure). But I wouldn’t worry about it.
deichwacht
14 Nov 2016 13:56
No, this happened because the stones were not cut precisely. In other rows, the fit is exact. In the end, there are still only a few joints that are slightly wider.
