ᐅ Why does the Malm bed creak in cold weather?
Created on: 21 Oct 2024 18:37
Mesugo
Mesugo
21 Oct 2024 18:37
I have had the Malm bed from Ikea for some time now, and I regularly notice that it starts creaking, especially during the colder months, whenever I move. I’m not just talking about occasional short noises, but rather a fairly persistent creaking that can be quite annoying.
I’m curious why this happens, as I suspect it might be related to the materials or the construction, possibly due to the expansion or contraction of wood or metal in the cold. I have already checked whether the screws are loose, but that doesn’t seem to be the main issue since the creaking continues. Are there any technical explanations or experiences regarding why the bed makes noise particularly in cold conditions?
I would really appreciate any explanations or tips on how to permanently prevent this creaking.
RENMA
21 Oct 2024 19:12
The creaking of a Malm bed in cold conditions can mainly be explained by the material properties and their behavior with temperature changes.
The wood, from which the frame is usually made, reacts to cold by slightly shrinking as the fine wood fibers lose moisture and contract. At the same time, metallic connectors, screws, and fittings may expand or contract differently, causing the wood and metal to rub against each other or move slightly.
These small movements can produce noises, especially creaking, if the contact surfaces are not sufficiently lubricated or if there is some play in the construction.
Regularly checking and tightening the screws can help, as can applying wax layers or special silicone greases to the joints to reduce friction.
This phenomenon is particularly pronounced at low temperatures because the materials contract more than they do at room temperature.
Overall, this is a physical effect that can hardly be completely prevented but can be significantly reduced with some maintenance and care.
dijan
21 Oct 2024 20:59
RENMA schrieb:
This phenomenon is even more noticeable in cold temperatures because the materials contract more than they do at room temperature.
That sums it up quite well! Cold isn’t just bad for your mood, but also for your Malm bed, which practically “complains” when it gets too tight 😉
I actually find it somewhat charming – the bed reminds you that it’s alive when you move around on it and the temperature drops. But joking aside, what really helps is tightening the screws thoroughly before winter and paying attention to the joints.
As RENMA mentioned, a bit of wax or silicone grease can work wonders without having to take everything apart. After all, you don’t want a creaking concert when all you want is a good night’s sleep :-)
If the creaking gets worse, you can also check the mattress toppers underneath, as sometimes they cause noises too. All in all, it’s an old story of wood, metal, and the weather playing between them.
Nabla64
22 Oct 2024 08:46
I would like to add a more detailed explanation and some tips that can help control the squeaking of the Malm bed in cold weather.
1. Causes and Mechanisms:
As mentioned before, temperature fluctuations cause wood and metal to react differently to the cold. Wood expands or contracts depending on moisture content and temperature, which creates stress in the joints.
Additionally, small gaps in the connections and tiny movements between the wood and metal at the screws can cause rubbing, leading to the typical squeaking sound.
2. Step-by-step Guide to Reduce Squeaking:
- First, tighten all visible screws using the appropriate tools. This prevents looseness and minimizes friction.
- Then, treat the connection points lightly with wax or a dry lubricant. Oil is often not ideal because it attracts dust.
- On contact areas between wood and metal, curtain tape or self-adhesive felt tape can help reduce friction.
- Make sure the slatted bed base is clean and in good condition, as it can also cause noises.
3. What to Avoid:
- Over-tightening screws can damage the wooden parts or warp the material.
- Lubricants containing oils or greases that can harden or become sticky are not recommended.
In summary: The squeaking results from the physical properties of the materials used combined with the construction. In cold weather, the effect is amplified by shrinking and tension. Regular maintenance and minor repair measures can significantly reduce the noise and extend the bed’s lifespan.
