I have been having an issue for some time now with my MALM bed from IKEA. I’ve noticed especially that the bed creaks quite a lot around the headboard area, and the noise is audible with every movement or when turning over in bed. I have already tried tightening all the screws, but that didn’t really help. The metal and wooden connections seem to be in good condition, and I have not overloaded the bed.
My question is: why does my MALM bed creak so much specifically at the headboard, even though I have ruled out common causes like loose screws? Are there any particular components or joints in this area that are especially prone to creaking noises?
I would really appreciate detailed advice or solutions, as the creaking really disturbs my sleep. Thanks in advance for your support!
Hello sefo48,
I’m familiar with the problem of a squeaking MALM bed at the headboard area—it happens more often than you might think!
It is usually caused by the connection point between the headboard and the bed frame. These parts are often made from engineered wood panels that rub against each other when moved. Even if the screws are tight, small movements between the wooden components or metal brackets can cause squeaking.
A good tip: try applying some talcum powder, silicone spray, or wax to the contact surfaces. These substances reduce friction and the squeaking noise. Just be careful not to get any liquid lubricants on the bedding or mattress.
If you haven’t already, also check whether the slat support points and the frame around the headboard are secure and clean—dust or small dirt particles can sometimes gather between the connecting surfaces.
Best regards and good luck!
sefo48 schrieb:
Why does my MALM bed squeak so much specifically at the headboard, even though I have ruled out all common causes like loose screws?
Hello sefo48!
It’s awesome that you can describe this in such detail! 🙂
I did the same, and it worked immediately for me!!! Simple steps – no expensive repairs. I love it when a little maintenance brings so much peace.
If that doesn’t help, you might want to check whether the headboard itself is slightly warped or damaged; sometimes small cracks appear there that cause noises.
Please keep us updated, and I’m hoping you can get a good night’s sleep again soon :-)
GiRoyce schrieb:
Try treating the contact points with some talcum powder, silicone spray, or wax.
For additional information:
The MALM bed is made from MDF panels and fasteners, which are particularly subjected to high stress in the headboard area. These connections between the headboard and side frame are typical spots where microscopic movements can occur due to varying stress, causing squeaking noises.
Yes, exactly. The so-called dowel joints and metal brackets in the headboard area are susceptible to this issue. Even with screws tightened securely, play can develop due to material fatigue or moisture in the wood.
A proper solution would be to:
- retighten all screws according to the specified torque
- treat contact surfaces with graphite powder or paraffin
- check for cracks in the connecting elements
Liquid lubricants are not recommended, as they can damage the material or cause long-term discoloration of the wood.
If you bought the bed secondhand, I suggest a thorough visual inspection of all wooden parts for stress cracks. These can be a cause of the noises.
sefo48 schrieb:
Are there specific components or connections in this area that are especially prone to squeaking sounds?
sancamille1 Nov 2020 07:56Squeaking is usually caused by friction at joints.
Check all screws on the headboard and connection points.
Apply lubricants such as graphite powder or talcum powder, ensuring not to damage the materials.
Sometimes the slat supports are loose or damaged.
Even if everything is tight, the bed can still squeak, as wood naturally expands and contracts.
I can completely understand how annoying it is when the bed squeaks right around the head area since that’s usually where there is the most direct contact and movement.
That’s really an important tip because such lubrication can cause more problems in everyday use.
I had a similar bed myself, and eventually it turned out that some wooden joints shifted slightly due to varying moisture levels from sweating, which made the squeaking worse. What helped me in the end was adding small wooden spacers at the contact points to reduce the movement.
Maybe you could also try checking if the bed sits more firmly on the floor or if a mattress with a thicker topper reduces the noise.
I’m definitely keeping my fingers crossed that you’ll be able to sleep without any issues again soon 🙂
GiRoyce schrieb:
But be careful that no liquid lubricants come into contact with the bedding or mattress.
