ᐅ Why does my BILLY bookshelf often wobble unexpectedly?
Created on: 27 Feb 2022 10:23
kian51
kian51
27 Feb 2022 10:23
Hello everyone, I have a Billy bookshelf from IKEA that I really like, but I’ve noticed it wobbles unexpectedly from time to time. Especially when I take something off the shelf or move nearby, it starts to sway slightly. It’s not extreme, but noticeable and somewhat unsettling. I’m wondering if this is due to the assembly, the floor surface, or perhaps the design of the shelf? Are there known reasons why a BILLY bookshelf might wobble unexpectedly, and what exactly can I do to fix it? I look forward to your advice and tips!
GAGRAHAM
27 Feb 2022 11:05
Oh wow, this is really a topic many of us are familiar with! :-) I think BILLY shelves are great, but the wobbling can be really annoying!
This is often because the shelves are relatively narrow and not always optimally fixed to the wall. Adding a wall bracket can work wonders!
Definitely do that; it will give you more stability and stop the wobbling! 🙂 Don’t be discouraged – it’s easier to do than you might think!
Marlenepa
27 Feb 2022 12:17
to better assess the wobbling of your BILLY shelf, it is important to know what type of floor it stands on (hardwood, tiles, carpet?) and whether it was assembled completely level.
Unfortunately, these shelves tend to wobble more easily due to their height and narrow design if they are not secured to the wall.
The installation of the back panel is also crucial: is the thin OSB board properly and tightly screwed in? This greatly stabilizes the structure. Sometimes it helps to retighten the screws and ensure the shelf is standing straight, possibly using small shims for leveling.
gasidney
27 Feb 2022 13:42
Wobbling is usually related to missing wall fastenings or an uneven floor. Check these two points first.
bensau
27 Feb 2022 14:08
I’m familiar with the problem of unexpected wobbling, and most of the time it’s like a little dance the shelf does when you get too close 😉.
Honestly: You can make a bit of noise, but it’s better to stop the shelf from moving by either attaching it to the wall or leveling the floor with small shims.
And if nothing else works – a new shelf with a wider base will bring stability to the place! 🕺
Parbo
28 Feb 2022 09:46
Marlenepa schrieb:
the installation of the back panel is crucial
Exactly, the back panel is often the underrated hero of BILLY shelves. It provides most of the stability.
A common mistake is not tightening the screws enough during assembly or not setting the shelf perfectly vertical. This can create tiny gaps that result in wobbling.
It is also recommended to use the included wall anchors, especially if the shelves are taller than 1.8 meters (6 feet) or if heavy books are stored.
A little anecdote on the side: I once had a BILLY shelf that wobbled until I realized that the floor on the left side was slightly uneven – a thin felt pad fixed everything.
