ᐅ Why does a securely fastened Billy bookcase still wobble?
Created on: 20 Dec 2020 19:07
pimuti
pimuti
20 Dec 2020 19:07
I recently installed a Billy bookshelf from IKEA – all screws and wall anchors are correctly and tightly fastened, the shelf is mounted on a solid wall, and I have also attached the appropriate brackets for wall mounting. However, it still wobbles when slight pressure is applied or when sitting on the edge. My specific question is: Why does a well-secured Billy bookshelf wobble even though it is supposed to be stable?
What factors could cause this apparent wobbling, and how can I make the shelf completely stable? I’m curious whether this might be due to the design itself, the material, the wall condition, or possibly the installation. Thanks in advance for your insights!
taudi
20 Dec 2020 19:25
Hello pimuti,
Your question is very well posed and concerns a common issue with shelving units like Billy. I will explain it step by step:
1. Construction-related flexibility: Billy shelves are mostly made from thin particleboard material, which appears sturdy but can easily bend under load or pressure. This causes some wobbling.
2. Wall mounting: Even if brackets are installed, the screws may not always be anchored into solid material (for example, drywall instead of solid brick) or the anchors may have some play. This results in movement.
3. Assembly accuracy: If the back panel is not fitted precisely or is slightly loose, this affects stability.
My advice: Try to ensure the wall fixing is anchored in solid material, use proper heavy-duty wall anchors, and consider adding additional cross braces or metal brackets. Regularly tightening the screws also helps.
In summary: The "wobbling" is usually a combination of material flexibility and less than fully secure wall anchoring.
KINMIN4
20 Dec 2020 19:54
Billy shelves often wobble because the back panel is not fully nailed or screwed in. Uneven floors can also cause instability. Check these first.
tangi
20 Dec 2020 20:15
taudi schrieb:
Design-related flexibility: Billy shelves are mostly made of thin particle board, which seems sturdy but tends to bend easily under load or pressure.
I would like to support this assessment. The thin material tends to warp under pressure, especially if the shelf is loaded in the upper sections and the mounting points on the wall are positioned lower.
Additionally, the quality of the wall mounting is crucial. Using only two brackets is often insufficient. Another solution can be reinforcing the back panel with an additional board or a thin plank to absorb shear forces.
It may seem trivial but is often critical for stability.
Julien
20 Dec 2020 21:03
Hello pimuti,
You have already considered the most important factors well yourself. I would like to explain a few additional basics that might help:
1. Load distribution: Billy shelves are mainly designed to be loaded symmetrically. However, if, for example, you sit on one front corner or place heavy objects there, leverage forces occur that cause the whole thing to wobble.
2. Wall type: Depending on whether the wall is made of drywall (plasterboard), brick, concrete, or timber (lightweight construction), the holding strength of the anchors varies. Using the wrong anchors for the wall type will cause the shelf to move, even if the screws are tightly fastened.
3. Movement allowance in the shelf: The wobbling can also result from clearance between the components—small gaps between the back panel and side panels often allow slight movement.
My recommendation: Use heavy-duty anchors suitable for the wall type, check the load distribution, and possibly reinforce the back panel with screws or additional bracing. This way, you can significantly improve the stability.
I hope this helps!
Le-so
20 Dec 2020 21:27
In addition to the points mentioned: Check if the shelf is standing level on the floor. Unevenness in the floor often causes wobbling, even if everything else is securely fastened.
