ᐅ Why does a securely fastened Billy bookcase still wobble?
Created on: 20 Dec 2020 19:07
pimuti
I recently installed a Billy bookshelf from IKEA – all screws and wall anchors are correctly and tightly fastened, the shelf is mounted on a solid wall, and I have also attached the appropriate brackets for wall mounting. However, it still wobbles when slight pressure is applied or when sitting on the edge. My specific question is: Why does a well-secured Billy bookshelf wobble even though it is supposed to be stable?
What factors could cause this apparent wobbling, and how can I make the shelf completely stable? I’m curious whether this might be due to the design itself, the material, the wall condition, or possibly the installation. Thanks in advance for your insights!
Elodie
21 Dec 2020 07:52
Hey pimuti and everyone else 😊
I always find it interesting how a simple Billy shelf can suddenly start wobbling, even though everything seems properly secured. The combination of lightweight material and the lack of diagonal bracing makes the shelf move easily – a bit like a little dancing leg.
Here’s my tip: An inexpensive and effective way to prevent this is to attach a small diagonal wooden strip to the back panel, acting like an "anti-dance leg." This greatly increases stability and costs almost nothing.
Also, placing a small pad (felt or rubber) under the front bottom edge helps prevent the shelf from sliding around on the floor.
Good luck with stabilizing, and talk to you soon! 🙂
Sebastianm
21 Dec 2020 08:33
Sometimes the screws themselves can wobble due to slight looseness. Loosen the screws again, reposition them, tighten, and check again after a few days.
KINMIN4
21 Dec 2020 09:11
Sebastianm schrieb:
Loosen the screws again, reposition them, tighten, and check again after a few days.\
Exactly, screws can loosen due to movement. This is often the cause when everything else is done correctly.
taudi
21 Dec 2020 10:46
Elodie schrieb:
An inexpensive and effective method to reinforce this is to attach a small diagonal wooden slat to the back panel, acting like a "counter supporting leg."
Exactly, a diagonal brace is a classic structural solution to prevent wobbling. It effectively resists lateral forces caused by shear stress.
As an addition: For Billy-style shelves, metal connectors or angle brackets also help if you want a more professional and durable solution. The key is to properly absorb and distribute the forces.
If you want to reinforce the shelf quickly and easily, use a wooden slat diagonally and firmly screw it in place – the effect is remarkable.
Kinbu
21 Dec 2020 13:30
Hello pimuti,
Your question is valid, as this wobbling is usually caused by more than one factor. I would like to revisit the wall mounting and the type of anchors used.
In many cases, the load caused by the weight plus leverage is underestimated. If anchors designed for light loads are used or if they are installed in hollow walls, wobbling is inevitable.
Also consider whether the shelf might be pressing against uneven floorboards or if it is not perfectly vertical. This, combined with material flexibility, causes wobbling.
A lasting tip is to reinforce the back of the shelf with a plywood panel (thick enough, about 6-8mm (1/4–5/16 inch)) and then attach it to the wall using more, better-distributed fixing points.
This significantly increases stability because all forces are distributed.
