I have a somewhat specific question: Why do some Billy shelves warp after extended use?
I am referring to the common issue where the shelves no longer stand straight after months or years, sometimes sag slightly, or the side panels bend. I am particularly interested in the causes at the material level and possible influences from the environment, load, or assembly. Are there specific weak points in the construction or common mistakes that lead to this warping?
Perhaps someone with experience knows the exact connections or can provide technical details about the wood panels, screws, or connecting hardware used. It would be great if the answers could be as detailed and well-founded as possible, so I can better understand the problem and, if possible, prevent it.
Hey Kaioda,
interesting question – I think almost everyone who owns a BILLY shelf at home is familiar with this. The shelves are actually nice and functional, but these deformations can be really annoying! 😉
One reason is definitely the material: BILLY is made of particleboard covered with a laminate. These boards can swell over time if moisture penetrates the wood – especially if the shelf is placed near windows or in damp rooms.
A bit of sunlight or temperature fluctuations can also cause the wood to "move" over time. Then there’s the load: if the shelf is overloaded or loaded unevenly, pressure builds up that bends the boards.
A combination of all this, and you end up with a crooked favorite piece of furniture.
As an addition: BILLY shelves are made from common standard materials—typically medium-density fiberboard (MDF) or particleboard with a melamine resin coating. While these materials are affordable and reasonably sturdy, they do absorb some moisture, which can cause swelling and thus warping.
Furthermore, the assembly instructions advise to avoid warping by attaching the shelves only to suitable wall types and not overloading them. Temperature effects from direct sunlight should also not be underestimated.
Stress can also arise from improper storage and assembly: if joints are not tightened correctly or screws are missing, the frame becomes less stable.
Overall, warping is caused by a combination of material properties, load, and assembly.
I would like to dive a bit deeper into the technical details here.
The warping of BILLY shelves can mainly be explained by the properties of the wood-based materials used. Particleboard and MDF are hygroscopic, meaning they absorb moisture from the air and release it again. This fluctuation in moisture content causes the material to expand or contract, resulting in mechanical stresses that can lead to warping.
For example, particleboard tends to swell more at the edges, as the protective foil is often thinner or missing there. The different moisture absorption between the coated surface and the core can also cause internal stresses.
Additionally, the problem is worsened by improper storage before assembly: If the panels are stored in a damp environment or exposed to constant temperature changes, the stresses are inevitable.
Another important factor is the type of connection used in the shelf. The usual dowels, screws, and cam lock fasteners used by IKEA are not designed for permanently extreme loads. Excessive loading, especially when uneven, can destabilize the frame and promote deformation.
When it comes to assembly, it is advisable to retighten the cam lock fasteners a few weeks after putting the shelf together to compensate for any settling.
Therefore, my question to you, Kaioda: In which room is your shelf located, and how is it loaded? Is it exposed to direct sunlight or high humidity?
Palenar schrieb:
In which room is your shelf located and how is it loaded? Is there direct sunlight or increased humidity?Thank you for the detailed response. My shelf is located in a living area without direct sunlight, fortunately. The humidity level is normal (not damp) and is controlled with a small dehumidifier.
It is usually loaded evenly with books. However, some of them are quite heavy, I estimate about 15–18 kg (33–40 lbs) per shelf. There was a period when it was less organized, with various stacks of folders and packages on it.
The assembly was done carefully: everything tightened, screws checked twice. Still, after about 4 years, you can see that the sides are slightly bowing outward, and the top shelf is somewhat sagging.
I wonder if this is simply natural material fatigue or if the load is the main cause.
Kaioda schrieb:
It is usually evenly loaded with books. However, some of them are really thick volumes.This is indeed an important point.
Shelves like the BILLY are designed for books, but they do have load limits stated in the assembly instructions. If you exceed the recommended maximum weight per shelf, the boards will gradually bend elastically.
This leads not only to sagging but also to permanent deformation because MDF and particleboard, while sturdy, do not have optimal resilience.
Additionally, a constant load promotes the development of internal stresses in the material, which can result in warping.
My advice: Try redistributing the heavy books or spreading them across multiple shelves and observe if the shelf stabilizes.
