ᐅ Why do some Billy doors no longer fit together properly?
Created on: 26 Aug 2023 08:23
didra
Hello everyone, I recently noticed that some doors of my IKEA Billy bookcases no longer fit together properly. More specifically, the hinges sometimes cannot be mounted correctly, or the doors stick when closing. I am curious about what might cause the contact points, meaning the areas on the door and the cabinet frame, to no longer align properly. Could there be changes in the materials, manufacturing tolerances, or am I encountering a known issue? I would appreciate any experiences or explanations as to why the fitting of doors fails specifically with some Billy bookcase doors.
Ankeli
27 Aug 2023 09:18
Let me summarize: Moisture, material deformation, and installation are the main reasons. Additionally, doors made by different manufacturers may not be 100% compatible, especially when replacing or purchasing additional units. It is important to check that everything fits securely and, if necessary, make adjustments.
narDietmar
27 Aug 2023 11:02
I would like to add an important point: with older furniture, the material often loses stability, and the surface coating can swell or peel. This further affects the hinges and the fit. Therefore, it is worthwhile to carefully check the condition, not only regarding assembly but also the material quality.
If you want to be on the safe side, you should pay attention to the production date when purchasing replacement doors, even if this is not immediately noticeable. Small variations can occur with doors from different production years.
noge58
28 Aug 2023 14:48
This is brilliant, how everyone is pitching in here! 😊 I had exactly the same problem once, so I completely removed the doors, let them dry overnight with the window open, and then readjusted everything – worked perfectly again!
labar43 schrieb:
I just fiddled with the hinges a bit, screwed and wiggled them
Exactly, just try it out and don’t get frustrated – sometimes it’s not a big deal.
vin_leo schrieb:
I just leave the doors slightly open during hot weather
Good idea, I do that now too, my Billy thanks me! 😄
V
vin_leo
29 Aug 2023 18:27
ankeli schrieb:
Moisture, material warping, and installation are the main causes
Exactly, that’s how you can tell a professional right away! 🙂
A little anecdote: I once tried to stop a squeaking noise by putting felt pads along the edges – and immediately ran into a slight fitting issue with the second door. So be careful with retrofits!
Conclusion: Just readjust every now and then and maintain the door mechanism – that works best.
