ᐅ Why do some Billy bookcases not fit into the intended space?
Created on: 15 Aug 2020 18:07
JOEMILIAHello everyone,
I recently bought a Billy bookcase from IKEA, which was supposed to fit perfectly into a niche in my wall. According to my tape measure and the wall plan, the niche is exactly 80 cm (31.5 inches) wide, which matches the standard width of the model. However, the bookcase won’t slide in — it either seems too wide or only fits in at an angle.
My question is: Why do some Billy bookcases not fit into the designated niche even though the measurements on paper should be the same? Are there tolerances from IKEA, manufacturing differences, or could it also be related to the construction of the wall or the niche? I would appreciate any specific experiences with the Billy bookcase and possible causes. Thanks in advance!
Most of the time, the issue lies with the recess itself: walls are rarely perfectly straight or exactly the stated width. Floors and ceilings can also be uneven. A tape measure alone is often not enough to capture this precisely.
Additionally, Billy shelves allow for some play but do not have large tolerances. If the space is too tight, it will not fit.
The issue is often due to several factors:
1. Manufacturing tolerances: IKEA specifies minimal tolerances for Billy units, which usually do not exceed a few millimeters.
2. Inaccuracies in the installation area: Walls and niches are often not perfectly square or even, and floors or ceilings may be uneven.
3. The material itself: Billy shelves are made of veneered particleboard, which can warp slightly when exposed to moisture.
4. Assembly: Sometimes the unit is not assembled completely square, which also affects the fit.
It is advisable to check the niche for unevenness and squareness using a spirit level and possibly a straightedge, and to measure the shelf area somewhat generously before purchase. In special cases, minor adjustments to the niche (e.g., sanding, leveling) may be necessary.
PIERCE schrieb:
Most of the time, the issue is with the niche itself: walls are rarely perfectly straight or exactly the specified width.Exactly! I once tried to squeeze a Billy shelf into a seemingly perfectly fitting niche—it just wouldn’t fit no matter what. The funny thing is, after some measuring and shifting around, I realized the wall was only about 5 mm (0.2 inches) off, and that really made a difference during installation.
On top of that, the Billy isn’t just a simple box you can compress. If the edges or the back panel have slight warping, or if the niche is even a little too small, the shelf just won’t cooperate. I was lucky with the angles back then and ended up securing the shelf with small wooden wedges—it holds perfectly! 🙂
To answer the question of why some Billy bookcases do not fit into the intended niche, here is a brief guide with the most important checkpoints and tips:
1. Accurate measurement: Use a spirit level, tape measure, and if necessary, a straightedge to measure the width, height, and depth of the niche. Make sure to measure at several points, as irregularities often occur only locally.
2. Check wall and floor conditions: Even small protrusions, grooves, moldings, or poorly plastered areas can reduce the width and available space.
3. Shelf tolerances: The Billy bookcase has specified dimensions (e.g., 80x28x202 cm (31½x11x79½ inches)), but there is a manufacturing tolerance of approximately ±2 mm (±0.08 inches). Although small, this can be significant in very tight fittings.
4. Assembly accuracy: Flat-pack furniture like the Billy must be assembled precisely. Uneven assembly reduces the fitting accuracy.
5. Moisture and material warping: Wood-based materials can swell or warp slightly depending on storage conditions or humidity.
6. Leave clearance: In practice, it is common to leave 5 to 10 mm (0.2 to 0.4 inches) of clearance on the sides to allow for easy installation and adjustment.
If all these points are considered, the bookcase should fit into the niche. If not, minor adjustments to the niche may be necessary (e.g., sanding down uneven spots or removing moldings).
In summary: The combination of slight wall irregularities, production tolerances, and assembly can cause fitting issues. It is best to double-check measurements, allow some clearance, and measure as precisely as possible.
