ᐅ Why can the back panel of BILLY shelves discolor or warp?
Created on: 30 Jan 2022 18:23
Tar_na
I have a question that has been on my mind for some time: Why can the back panels of IKEA BILLY bookcases discolor or appear warped after a while?
I have noticed that some back panels turn yellowish or brownish, and sometimes the boards slightly warp, which affects both stability and appearance. This doesn’t seem to happen to every back panel, so I suspect it may be related to the material or environmental conditions.
Does anyone have an idea what exactly could cause this? Is it due to the material of the back panel (often simple hardboard / particleboard)? Could moisture or direct sunlight be the triggers? Or maybe a combination of storage conditions and the coating or paint? I would like to know what to keep in mind to minimize discoloration or warping, and if there are typical quality differences in BILLY bookcases that influence this.
Thank you for your insights!
Deandre
31 Jan 2022 09:02
FLONE41, that is a very well-observed point. Air quality and humidity are often underestimated factors.
FLONE41 schrieb:
Regarding the discoloration: I suspect that chemicals from the air as well as deposits on the surface can contribute to yellowing.
That's correct, so-called VOCs (volatile organic compounds) indoors can alter the surface. A room with poor ventilation and high humidity promotes mold, odors, and also chemical reactions on furniture surfaces.
A dehumidifier can help, especially in basements or damp environments, to keep the back wall dry and stable. Regular airing is also recommended.
Additionally, I suggest installing UV-blocking films on windows when possible, especially on south- or west-facing windows.
Espen
31 Jan 2022 09:47
Summary:
- Back panel is thin, made of particleboard or hardboard
- Absorbs moisture and swells
- Sunlight causes yellowing
- UV radiation alters paint/coating
- Proper storage: dry, shaded, well-ventilated
- Installation must be done correctly
Warping is always related to moisture. Discoloration is caused by UV exposure.
FAVALERIE9
1 Feb 2022 10:03
A small addition: There are replacement back panels made from thicker materials or MDF that are somewhat more durable. Ikea sometimes offers sturdier back panels as accessories.
If appearance matters to you, such a replacement can be helpful.
Tar_na
2 Feb 2022 15:21
Thank you for the very helpful and diverse information!
Deandre schrieb:
Discoloration often occurs due to UV exposure, which chemically alters the paint or surface.
Gregory schrieb:
Warping happens because of an imbalance in the material: one side absorbs moisture while the other absorbs less.
This confirms my assumption that it is really the combination of light and moisture causing the problem. In that sense, it seems unavoidable if the shelves are not placed in ideal locations. At least this makes it easier to choose the best spot more consciously.
I also learned how important it is to properly secure the back panel. If the back panel remains loose, it increases the risk of warping.
The tip about using a dehumidifier and UV-protective film also sounds very reasonable; I will give that a try.
Thanks again for your efforts!
