ᐅ Why can the back panel of BILLY shelves discolor or warp?
Created on: 30 Jan 2022 18:23
Tar_na
Tar_na
30 Jan 2022 18:23
I have a question that has been on my mind for some time: Why can the back panels of IKEA BILLY bookcases discolor or appear warped after a while?
I have noticed that some back panels turn yellowish or brownish, and sometimes the boards slightly warp, which affects both stability and appearance. This doesn’t seem to happen to every back panel, so I suspect it may be related to the material or environmental conditions.
Does anyone have an idea what exactly could cause this? Is it due to the material of the back panel (often simple hardboard / particleboard)? Could moisture or direct sunlight be the triggers? Or maybe a combination of storage conditions and the coating or paint? I would like to know what to keep in mind to minimize discoloration or warping, and if there are typical quality differences in BILLY bookcases that influence this.
Thank you for your insights!
Deandre
30 Jan 2022 18:37
Hello Tar_na,
your questions are very well formulated. In general, the back panel of BILLY shelves is usually made of thin hardboard or particleboard, coated with lacquer or foil. These materials are sensitive to moisture and temperature fluctuations.
Discoloration often occurs due to UV exposure, which chemically alters the lacquer or surface. If the back panel also absorbs moisture, the material swells, leading to warping or bowing.
Additionally, IKEA uses different manufacturing processes that can slightly affect the resistance against environmental influences. But essentially, it is the combination of material quality, indoor climate (humidity, temperature), and sunlight exposure that causes this effect.
I recommend placing the shelf away from direct sunlight through windows and ensuring good ventilation. It is also important to avoid the back panel staying damp for extended periods—such as from water vapor or condensation.
Mufato
30 Jan 2022 18:42
The back panel is simply thin and made of particleboard. Moisture and sunlight cause discoloration and warping. Store it in a dry, shaded place to keep it in good condition for longer.
Gregory
30 Jan 2022 19:08
Tar_na, to answer your question more precisely: The back panel of a BILLY shelf is usually made of a thin hardboard (MDF or HDF, depending on the batch) with a paper or film coating.
This coating is susceptible to UV radiation, which can cause discoloration over time. Additionally, the core material swells with increased humidity, causing the back panel to warp. This warping happens due to an imbalance in the material: one side absorbs moisture more than the other.
IKEA uses cost-effective materials, so these effects are more noticeable compared to higher-quality furniture. To minimize deformation, it is advisable to place the shelf in a room with stable temperature and good ventilation. Direct sunlight on the back should be avoided, as the thin panel is relatively translucent and therefore enhances UV-related discoloration.
Assembly also plays a role: a missing or improperly attached back panel is more prone to warping.
angel
30 Jan 2022 19:32
Thanks for the clear explanations so far, Gregory and Deandre!
I just want to add that I have personally experienced that back panels placed against damp walls warped significantly within a few months. The material of these back panels easily absorbs moisture.
Gregory schrieb:
The back panel usually consists of a thin hardboard with a paper or foil coating.
This coating is susceptible to UV radiation, which causes color changes over time.
That’s true, after about a year in my home office, the back panels of the BILLY shelf have become very yellowed, even though the shelf is not directly by a window. I suspect daylight is enough to cause the discoloration.
You can also replace the back panel, but it’s more cost-effective to ensure suitable conditions from the start.
FLONE41
31 Jan 2022 08:15
I wanted to share my two cents as well ;-)
Tar_na schrieb:
I’ve noticed that some back panels turn yellowish or brownish, and sometimes the boards even warp slightly, which affects both stability and appearance.
That’s exactly what I’ve experienced too, and it always annoys me. You feel like the nice piece of furniture is “aging” or even getting damaged because of the discoloration.
In my apartment, the humidity level is relatively high, which is probably not ideal. Since the back panel is so thin, I get the impression that it doesn’t handle environmental influences very well.
Regarding the discoloration: I suspect that chemicals in the air and deposits on the surface might accelerate the yellowing. Has anyone else noticed if ventilation or using a dehumidifier helps? I have such a device and already see a difference with my furniture overall, but with the back panel of the BILLY bookcase, it still seems almost unavoidable.
