ᐅ Why are some Billy bookcases more prone to scratches and dents?
Created on: 22 Aug 2021 08:37
Baualexand
Baualexand
22 Aug 2021 08:37
Why are some Billy shelves more prone to scratches and dents than others? I have the impression that, even with seemingly identical models made from the same material, there are differences in surface quality and durability that become noticeable with heavy use. I am especially interested in whether factors such as the production batch, the type of particleboard used, the coating, or possibly even the assembly process could play a role. Are there manufacturing variations that could make the shelf more vulnerable? And could this also affect how easily minor damages can be prevented or repaired?
Genevieve
22 Aug 2021 09:14
Baualexand schrieb:
I have the feeling that apparently identical models made from the same material show differences in surface texture and durability
That is an interesting observation, but I would question it. As far as I know, IKEA manufactures their Billy shelves using standardized processes, so the material should be consistent. I would rather suspect that the scratches and dents result less from manufacturing and more from use—such as how the shelves were handled, assembled, or moved. Are there any proofs or examples supporting your claim that there might be differences in the surface or material?
NIKA61
22 Aug 2021 11:02
Surface quality, installation, and use are the most important factors. Cheaper particle boards are more susceptible to damage. If there are already damages upon delivery, claim a refund or replacement.
flo-Theres
22 Aug 2021 14:43
It is quite possible that there are slight differences within a product series, even if minimal. Small variations in the density of the particleboard or the coating can affect scratch resistance.
Additionally, improper assembly or the absence of protective felt pads on the feet can compromise stability and lead to dents. Storage and transportation before installation also have an impact. Higher-quality clear coats or melamine resin coatings would be more durable; however, IKEA usually does not offer such options.
Layla
23 Aug 2021 07:19
I can well understand how frustrating it is when your Billy shelf shows visible damage sooner than expected. I’ve noticed that the areas most affected are often those that are bumped into more frequently or where items are regularly moved around.
Perhaps it’s also because some surfaces haven’t fully cured by the time the shelves are delivered? I’ve had furniture myself where the surface changed slightly after 2-3 weeks.
It also seems important to handle the shelf carefully and protect the edges if possible, for example, with soft covers or suitable protective measures. If you love your furniture, you unfortunately have to take care of it too :-)
lalutau
23 Aug 2021 09:57
Baualexand schrieb:
Are there differences in manufacturing that make the shelf more sensitive?
The materials used for Billy shelves are mostly MDF or particleboard, coated with a melamine resin foil. This process is standardized, but slight variations can occur during production, such as differences in the coating thickness or the quality of the particleboard, which can affect scratch resistance.
Storage conditions also play an important role. High humidity or temperature fluctuations can cause the material to swell, making the surface more vulnerable.
Another factor is assembly. Incorrect assembly or the absence of protective feet can easily cause dents when the furniture is moved.
I recommend applying a special repair paste for particleboard surfaces to minimize small scratches if the surface is damaged.
