ᐅ Why are some BILLY shelving units made of wood less expensive than others, and what does that mean for their quality?
Created on: 13 Jun 2018 08:37
klaju
klaju
13 Jun 2018 08:37
I noticed that some BILLY wooden shelves at Ikea are offered at a lower price than others, even though they look quite similar. So I’m curious: Why are some BILLY wooden shelves cheaper than others, and what does that mean concretely for the quality? Is it just about different types of wood, or do manufacturing techniques, workmanship, and possibly even origin also play a role? I’d also be interested to know how this affects durability and stability, especially if the shelf is used more intensively. Does anyone have experience or expert knowledge on this?
botibo
13 Jun 2018 10:42
Good question! 🙂 With BILLY shelves, there are actually differences in material and workmanship that you might not notice at first glance. IKEA often uses particleboard with a decorative laminate on the cheaper models, while the more expensive versions feature MDF panels with real veneer.
Exactly! The type of wood composite is important. MDF is more stable and resistant to moisture, while particleboard is more affordable but somewhat more prone to damage.
Regarding quality: if you plan to heavily load the shelf or use it for a long time, the more expensive option is usually worth it. But for lighter items, the cheaper shelves often do the job. So, quality generally corresponds with price, but not always dramatically!
Fredlo
13 Jun 2018 11:55
Wow, I really love my BILLY shelves! 🙂 I first had a cheaper model, then later got a more expensive one with real wood veneer – and yes, you can definitely notice the difference!
botibo schrieb:
The wood composite matters. MDF is more stable and resistant to moisture, while particleboard is more affordable but a bit more prone to damage.
I can totally confirm that. My cheaper shelf started to wobble slightly after a few years, but the more expensive one is still very stable and looks better.
So, if your budget allows, it’s worth investing a bit more – it pays off! 👍
REPITAR
14 Jun 2018 09:18
To clearly explain the differences, here is a brief overview:
1. Material:
- Particle board: more affordable, lighter, but less durable and more susceptible to moisture.
- MDF board: denser, smoother, better surface, more stable and longer lasting.
2. Surface:
- Paint or laminate also affect durability and appearance.
3. Manufacturing:
- More expensive models are often made with finer fittings, better edge finishes, and higher precision.
4. Origin:
- Depending on the place of production, quality control can vary, which influences the final quality.
In summary: A more affordable BILLY shelf can be completely adequate for occasional use. However, if the shelf will be heavily loaded or used long-term, versions with MDF and higher-quality manufacturing are recommended.
Tip: When purchasing, pay attention to the manufacturer’s information on materials and, if available, customer reviews.
tetan
15 Jun 2018 15:03
klaju schrieb:
What does this specifically mean for quality?
Quality mainly depends on the type of wood and the manufacturing process. Particleboard is more affordable but less durable, while MDF provides greater strength and better surface finishes. Price differences often reflect the shelves’ lifespan and load-bearing capacity.
