ᐅ Which wood finishes are suitable for Ikea Hemnes furniture?
Created on: 6 Nov 2020 19:27
na_san
na_san
6 Nov 2020 19:27
I have a fairly specific question as I am currently working on refurbishing my Ikea Hemnes furniture. The wood surfaces are untreated or only whitewashed, and I plan to upgrade the furniture using sustainable and as durable as possible wood finishes.
My main question is: Which wood finishes are particularly suitable for Ikea Hemnes furniture made of solid pine if you want to achieve a durable, visually appealing, and easy-to-maintain surface?
I would also like to know:
- Which finishes adhere well to the mostly slightly pre-coated wood?
- Whether linseed oil, hard oil, varnish, or chalk paint are recommended?
- What special considerations should be taken into account during preparation (sanding, priming, etc.)?
I look forward to detailed advice, preferably based on personal experience, so that the new look lasts as long as possible and the wood stays protected. Thanks in advance!
Kurtis5
6 Nov 2020 20:03
Hello na_san,
For Ikea Hemnes, I recommend water-based clear varnish. It provides good protection and adheres well to pine.
Make sure to sand thoroughly beforehand, remove dust, and then apply the varnish in thin layers.
Linseed oil offers little protection against moisture.
jelite
7 Nov 2020 08:46
Hello na_san,
I would like to explain in more detail which wood finishes work well for Ikea Hemnes furniture and what to consider:
First, a bit about the material: Hemnes is made of solid pine wood, often with a white glaze. This glaze is usually slightly opaque, so the surface is not completely raw but also not heavily sealed.
1. Preparation:
- Always sand thoroughly! Use fine sandpaper (grit 120 to 180) to roughen the surface and remove some of the old glaze.
- After sanding, remove dust—ideally with a damp cloth or vacuum cleaner.
2. Finishing options:
- Acrylic or water-based acrylic paint is recommended for durability and protection. It is easy to apply, dries quickly, and often has low odor.
- Hard oil (for example, a linseed oil-resin blend) can look good and enhance the wood grain but provides less protection against moisture and mechanical wear.
- Chalk paints are trendy but must be sealed with clear varnish or hard wax; otherwise, they are quite sensitive.
3. Before painting, it is often advisable to use a primer, especially on highly absorbent woods like pine, to achieve a more even finish and better coverage.
4. Special considerations:
- Room humidity and usage (kitchen vs. bedroom) should be taken into account when choosing the product.
- Apply several thin coats, sanding lightly between layers for better adhesion.
5. Personal tip:
I have treated Hemnes tables with acrylic paint and was satisfied because the surface stayed well protected while still feeling pleasant.
I hope this helps you a bit!
Edric
7 Nov 2020 21:13
jelite schrieb:
I treated Hemnes tables with acrylic lacquer and was satisfied because the surface was well protected while remaining pleasant to the touch.
That sounds very helpful, thank you for the detailed insights!
I wanted to add that I hesitated for a long time about modifying my Hemnes furniture because I like the simple design, but the protection and durability have become more important to me.
A small warning to anyone considering using oils: I tried some linseed oil, and although the wood looked matte and warm, I felt that despite a wax coating, it wore off quickly and then became blotchy.
Of course, I would appreciate it if someone could share their positive experiences with hard oil here, as I am still interested in this topic. Overall, I think it’s good to consider before painting how much effort you want to invest and how sensitive the piece of furniture can be afterwards.
