ᐅ Which tools make it easier to assemble Ikea Metod kitchens by yourself?
Created on: 15 May 2019 09:27
Dagla46Hello everyone, I am currently planning to install an Ikea Metod kitchen in my apartment and would like to do it mostly on my own. I’m wondering which tools are truly recommended for assembling the individual cabinets, doors, and drawers efficiently and neatly. I’m especially interested in practical tools that reduce the effort needed for aligning and screwing, but also help with small adjustments without having to constantly reach for more hardware store or power tools. Does anyone have experience with devices or aids that significantly simplify assembling Metod kitchens and perhaps tips on which tools are less necessary? I have already considered a cordless drill, spirit level, and jigsaw, but I am open to specific recommendations and helpful advice, including for precision measuring or marking tools that might speed up the process. Thanks in advance for your input!
Dagla46 schrieb:
For me, particularly practical tools that reduce the effort when aligning and screwing are interestingThat sums it up quite well. The most important tool is definitely a good, powerful cordless drill with high torque control – this prevents over-tightening the screws and damaging the cabinets. I strongly recommend a spirit level with a magnetic strip, especially a digital angled version. It makes aligning the cabinets much easier and speeds up the assembly process.
Besides that, a good set of step drill bits or spade bits is helpful in case you need to drill holes for adjustments. Some people also underestimate the importance of bar clamps. They are unbeatable for holding the cabinets precisely together while you’re fastening the screws. Finally, I suggest having a small hammer with a plastic head – it protects surfaces when setting dowels or aligning the fronts.
My experience comes from several kitchen renovations, where especially with Metod cabinets there are often minor inaccuracies that you can quickly compensate for with the right tools.
Alberto5116 May 2019 07:18Dagla46 schrieb:
Does anyone have experience with which tools or aids significantly simplify the assembly of Metod kitchens and maybe tips on which are less necessary?I can completely understand how complex the topic of tools can be, especially if you’re unsure or have little experience with kitchen installations. For me, besides a cordless drill and a spirit level, investing in a long, sturdy carpenter's square was very helpful, particularly for keeping the base cabinets perfectly aligned at the same height.
What I found less useful was a jigsaw. Ikea Metod is quite pre-planned, and the carcasses usually fit precisely—exceptions being special customizations or unique requests. If you’re not confident with it, I would worry that using a jigsaw might lead to measuring errors unless you’re practiced.
What I highly recommend, however, are marking tools like a marking pencil combined with a small set of different drill bits. This way, you can drill precise pilot holes without damaging the wood. At first, I felt very uncertain with these tasks, but with proper preparation and good tools, handling them quickly becomes routine.
I wish you the best of luck—it’s definitely achievable and even enjoyable once you get the hang of it.
Giagau schrieb:
I definitely recommend a spirit level with a magnetic edge, ideally a digital angle version.I agree, that tool is worth its weight in gold!
When you’re installing all the screws, I also strongly suggest having some patience and preferably a cordless screwdriver with interchangeable bits. It saves your nerves and reduces arm fatigue. When I built my Metod kitchen, a little helper made a big difference: a simple magnetic bit holder. It holds the screw firmly when you’re working alone – especially handy in tight spaces or when you don’t have a workbench.
Oh, and don’t be intimidated by the pile of instructions. The right tools make all the difference, and a bit of humor helps too – it’s easier if you have a laugh now and then. 😉
Good luck to all kitchen builders!
