ᐅ Which spare parts for IKEA PLATSA are most commonly damaged?
Created on: 1 Jul 2019 13:27
Pamosan
Pamosan
1 Jul 2019 13:27
Hello everyone, I am currently looking into the durability of the IKEA Platsa series, especially regarding spare parts and their longevity. I am particularly interested in which spare parts in the PLATSA system tend to break most often or show defects for users that then need to be replaced. Have any of you had experience with this, for example, whether certain hinges, connectors, drawer slides, or back panels tend to wear out more quickly or cause problems more frequently in everyday use? I would appreciate it if you could provide as much specific information as possible about the parts affected and perhaps share tips on how to prevent these issues. Thanks in advance!
Le-so
1 Jul 2019 13:48
In my experience, it is mainly the hinges on PLATSA that tend to give way. Often, the door gets stuck or cannot be closed properly anymore. The small connectors (so-called "dowels") can also break after repeated disassembly. Usually, the only solution is to get replacements.
FLONE41
1 Jul 2019 15:11
I find it interesting that you are addressing this topic so specifically, as I have often wondered which parts of the PLATSA furniture are actually the weak points. For me, it was the bottom of the drawers, which warped after some time – initially, this was surprising because you don’t usually expect that from a piece of furniture that is supposed to be sturdy. It always feels a bit disappointing when you realize a part does not hold up as you had expected. Have you or anyone else had similar experiences? I believe that with modular systems like this, the joints are generally the most critical points.
Pamosan
2 Jul 2019 09:04
FLONE41 schrieb:
For me, it was partly the bottom of the drawers that warped after some time
That sounds like an important point I hadn’t really considered before. The drawer bottom certainly has to withstand a lot; I wonder whether the material is generally prone to warping or if this is more likely due to overloading.
On the topic of hinges and dowels, as Le-so already mentioned, I’m curious if anyone suspects that the installation process or frequent moving of the furniture has a significant impact on the durability of these parts?
More specifically, I’m also interested in whether IKEA itself provides official replacement parts lists or recommendations on which components tend to need replacing most often, to get a better overview. Perhaps someone has access to this kind of information or can share how straightforward the spare parts supply is for PLATSA.
pauPierce
3 Jul 2019 18:33
To look at the topic from a more technical perspective: with PLATSA, the most common weak points are often the connecting fittings—especially the so-called "soft-close hinges" and the plastic clips that hold the back panels. These parts are well designed, but the material is heavily stressed due to the modular construction.
Typically, the approach is as follows:
- The hinges can become loose over time due to excessive load or frequent opening, which leads to doors not closing properly. Replacement hinges are relatively easy to obtain as individual parts from IKEA.
- The dowels or plastic connectors (particularly the clips that secure the back panel) often loosen or break with frequent disassembly. It is advisable to work carefully and handle these parts gently.
- For the drawers, I have noticed that the bottom panel tends to swell when exposed to moisture. This usually only happens with improper storage or incorrect use.
Does assembly cause damage? Yes, especially if you build and take apart the unit multiple times, the clips and connectors can be damaged. The screws themselves generally hold up well and are not usually the issue.
Regarding spare parts availability, I can say that IKEA has a fairly good spare parts service at many locations, including for PLATSA. If in doubt, ordering online is helpful, although not all small parts can be ordered individually, which can occasionally be a bit frustrating.
If you have more specific questions about individual components, I’m happy to go into further detail.
