Good morning everyone, I have a question for those who often use or disassemble Malm-type furniture: Based on your experience, which replacement parts are most commonly needed for MALM dressers and beds? I am especially interested in the parts that typically wear out or break during regular use or over time. I am not looking for a general list, but rather specific examples or practical insights to better assess and prepare for repairs. Additionally, it would be helpful to know if there are common weak points that tend to cause issues more frequently, such as screws, hinges, or other mechanical components. Thanks in advance for your feedback!
Kurtis5 schrieb:
The sliders under the drawers in MALM are often defectiveThis matches my experience as well. Additionally, it’s worth noting the common issue with the plastic drawer runners, which can break under load. The thin wood of the back panel is also a weak point, as it can easily crack or break when the furniture is moved frequently or stressed. Metal fittings such as screws and brackets tend to bend less often if the assembly is done correctly. The most relevant parts for replacements in practice are therefore:
- Drawer runners (especially the plastic guide rails)
- Sliders or rollers
- Back panels
These components should be regularly checked and replaced if necessary after extended use.
herschel schrieb:
Are there typical weak points that often cause problems, such as screws, hinges, or other mechanical partsI would like to add that the hinges on MALM furniture tend to be quite sturdy, provided the furniture is assembled correctly. Issues usually arise from incorrect assembly or overloading. However, the back panel is often the real problem, as it is thin, fixed in place, and prone to cracking with frequent movement or transport. Replacement parts for the back panel are inexpensive but often underestimated if the furniture is moved frequently.
sihau schrieb:
Plastic drawer slides that can break under loadIt’s interesting that you mention the slides – I see this more as a design flaw. In my opinion, if the MALM drawer slides break regularly, the furniture really can’t meet high quality standards. After all, you pay for furniture that is reasonably sturdy and doesn’t constantly need replacement parts.
Foster63 schrieb:
Back panel is actually the problem, as it’s thin, fixed, and prone to tearingThat’s understandable, but honestly, the back panel doesn’t usually bother me during regular use. I think anyone who treats their furniture with a back panel like fragile glass should probably consider becoming a tradesperson rather than buying furniture. ;-)
Replacement parts are fine, but if you have to keep buying them all the time, there’s definitely a design flaw somewhere in the concept.
LEOIX schrieb:
If the MALM drawer slides regularly break, then the furniture really cannot meet high-quality standardsThat is a valid point; however, the price-sensitive segment in which MALM operates is specifically designed for budget-conscious customers. The use of plastic slides and thin back panels is a deliberate design choice to keep the furniture affordable while still functional.
From a technical perspective, it can be said:
- The drawer slides are indeed sensitive to heavy loads or frequent use.
- Screws and fasteners should be carefully secured during assembly to prevent misalignment and damage.
My advice: If higher usage levels are expected, it is advisable to proactively upgrade to stronger drawer slides or opt for metal alternatives when replacing parts.
