ᐅ Which screws are suitable for reinforcing Billy bookcases?
Created on: 2 Apr 2023 10:27
drapin
drapin
2 Apr 2023 10:27
I have a somewhat specific question: I want to reinforce my Billy shelves because I plan to store heavy books and possibly some decorative items in them. Since I want to rely not only on visual stability but also on safety and durability, I am mainly interested in which screws are best suited for reinforcing the shelves.
Specifically, I am wondering if it is worth replacing the supplied thin particleboard screws with galvanized or possibly stainless steel screws. I would also like to know the optimal dimensions (length/diameter) to avoid splitting the material while still ensuring a strong hold. Are there any practical experiences that can help in making the right choice?
Thank you in advance for your advice!
Leote
2 Apr 2023 11:03
For reinforcing Billy shelves, I recommend using 4 mm (5/32 inch) thick chipboard screws with a length of about 40–50 mm (1 5/8–2 inches). Galvanized screws are better than plain ones because they do not rust. Make sure to attach the screws at the joints and on the back panels to improve stability.
Ethan
2 Apr 2023 16:49
Hello drapin,
I think your question is very sensible, especially when it comes to reinforcing Billy shelves. The original screws from Ikea are usually particleboard screws with a rather thin diameter, which can quickly become a problem under heavy load.
As Leote already mentioned, 4 mm screws are a good choice. I recommend galvanized particleboard screws because they are both corrosion-resistant and suitable for wood-based materials. Stainless steel is even better against rust but is usually unnecessarily expensive if the shelf is kept in a dry environment.
Regarding the length: 40 mm (1.6 inches) is often sufficient if you place the screws in the load-bearing parts. It is important not to use screws that are too long to avoid splitting or piercing the wood on the backside.
If you plan very heavy loads, it might also be worthwhile to use so-called barrel nuts or connector bolts in addition. This will make the shelf significantly more stable.
I hope this helps. If you like, I can also provide some sources for suitable screws.
Best regards!
sifope
3 Apr 2023 08:12
Leote schrieb:
Galvanized screws are better than plain ones because they don’t rust.
That is correct, but it should be questioned whether simply choosing galvanized particleboard screws adequately addresses the stability issue. When reinforcing Billy bookcases, it’s not only about corrosion protection but mainly about selecting the right screws regarding diameter and length in combination with the density of the shelf material.
Ethan schrieb:
40 mm (1.6 inches) is often sufficient if you use the screws on the load-bearing parts.
It is also important to consider load distribution. If reinforcement is only applied locally, the screws in the shelf sides can cause the wood to tear out, especially if the material is already somewhat porous or aged.
One suggestion: Before thinking about changing screws, identify the weak points of the shelf (usually the bottom or back panel) and possibly add additional support strips there, which can then be fixed with stronger screws. This way, the force is better distributed, and the risk of material failure is reduced.
What do you think? Is it really enough to just use thicker or longer screws without considering the overall reinforcement concept?
