ᐅ What protective measures are effective against moisture in Malm clay?
Created on: 4 Apr 2020 08:37
Meo-nu
I am currently working on a topic that should be relevant for everyone involved with the Malm lithostratigraphy complex in buildings or rock formations: What protective measures are effective against moisture in Malm?
Specifically, I mean which construction or chemical techniques can be reliably used to minimize the penetration of water or moisture, or to protect the rock from damage caused by moisture exposure.
I am particularly interested in advice and experiences related to waterproofing and moisture protection in construction projects in Malm areas, as well as practical tips on dealing with the characteristic porosity and type of limestone. Are there established methods that are generally recommended? What mistakes should definitely be avoided?
Thank you in advance for your input!
Here is a brief guide on how to proceed systematically:
1. Cause investigation: First, it is essential to determine exactly why the walls are damp – rising damp, lateral groundwater, or condensation.
2. Insulation and waterproofing concept: Depending on the cause, either exterior or interior waterproofing is planned. In the case of Malm, it is important to pay attention to the vapor permeability of the material.
3. Techniques:
• Exterior waterproofing with plastic membranes or bitumen plus drainage.
• Interior waterproofing with mineral-based sealing slurries or special interior waterproofing coatings.
• Hydrophobic impregnations to protect masonry under low moisture exposure.
• Injections for targeted crack repairs.
4. Ventilation: Good ventilation or dehumidification is essential for basements to prevent condensation-related moisture.
5. Control measures: After remediation, moisture levels should be monitored using moisture meters.
Here, I consider a combination of measures to be overall the most successful. However, this always depends on the specific conditions.
3. Techniques:
Meo-nu schrieb:
Welche Schutzmaßnahmen helfen gegen Feuchtigkeit bei Malm?
Guyju schrieb:
Here I see a combination of measures as the most effective overall. That’s exactly what I wanted to add. From my experience, there is no way around combining drainage, possibly external waterproofing, and additional internal waterproofing.
Especially with Malm limestone, since the rock can absorb water due to its structure and dries very slowly, the measures should be designed so that residual moisture is not trapped. Otherwise, long-term damage can occur.
Meo-nu schrieb:
Renovation without complete gutting or rebuilding That is challenging because the best results are often achieved only with external waterproofing and drainage. However, with modern injection techniques and highly vapor-permeable internal waterproofing, good results can also be obtained.
My question: How damp are the basement walls currently? Are there already signs of salt damage or plaster flaking?
