ᐅ What types of pollutants or harmful substances can be present in Ikea HEMNES products?
Created on: 6 May 2019 13:47
V
vaughn62
V
vaughn62
6 May 2019 13:47
I recently purchased a piece of furniture from the Ikea Hemnes series and have been looking more closely into possible harmful substances that may be present in the materials and manufacturing process. My specific question is: What types of harmful substances might be found in furniture from the Ikea Hemnes range, what potential health risks could they pose, and to what extent do these products comply with current standards and regulations regarding harmful substances?
I am particularly interested in aspects related to formaldehyde, plasticizers, and any solvents that might be used in finishes or paints. Are there any experiences or reports concerning the detection of harmful substances in this series?
Thank you in advance for your informed opinions and tips on how to safely use these furniture pieces in a home environment.
bujufa
7 May 2019 09:33
Hello vaughn62,
to answer your question precisely: Ikea mainly uses solid pine wood and MDF panels for the HEMNES series. Formaldehyde can be present, especially in the MDF components, as it is often used as a binder in engineered wood products. Ikea states that their products strictly comply with European emission limits, such as the E1 standard for formaldehyde.
- Formaldehyde: Can be released from the wood-based materials; Ikea documents low levels.
- Plasticizers: Are hardly used in HEMNES products, as the coatings are mostly water-based.
- Coatings and paints: Mostly water-based coatings with low solvent content are applied.
It is important to ventilate the furniture well after assembly, as this further reduces emissions. Ikea’s standard test reports guarantee no health risk under normal use conditions.
If you are particularly sensitive, additional indoor air quality measurements are recommended.
I hope this gives you a clear basis.
Far34
7 May 2019 11:04
Briefly: The HEMNES collection is manufactured according to EU standards, meaning formaldehyde levels are below limit values. Plasticizers are barely present. A water-based finish reduces solvent emissions. Ventilation always helps.
Fitigu
8 May 2019 17:26
bujufa schrieb:
Ikea mainly uses solid pine wood and MDF panels for the HEMNES series. Formaldehyde can occur, especially in the MDF components, as it is often used as a binder in engineered wood products.
This is precisely the relevant point. Formaldehyde is produced as a byproduct of resin usage during the processing of engineered wood products, particularly MDF. Studies show that emission levels in Ikea furniture are usually well below the E1 standard limits (maximum 0.1 ppm formaldehyde).
Additionally, some paint or varnish layers may contain small amounts of volatile organic compounds (VOCs), but these are minimized in the HEMNES series due to the use of water-based coatings.
- Formaldehyde health risk: Respiratory irritation is possible at high concentrations, but levels in Ikea furniture are generally considered safe.
- Plasticizers: HEMNES does not use these significantly, unlike furniture containing plastics.
An objective risk assessment does not indicate cause for concern under normal living conditions. I am also aware that Ikea regularly conducts internal testing and places importance on certifications.
Nevertheless, thorough airing out of newly assembled furniture is recommended, especially when combining several pieces. This reduces any potential emissions into indoor air.
If anyone has experience with measurements or symptoms, it would be interesting to hear about them.
