ᐅ Which LED lighting systems are best suited for IKEA BESTA shelving units?
Created on: 28 Feb 2020 18:23
Jankora
Jankora
28 Feb 2020 18:23
I am planning to equip my IKEA BESTÅ shelves with LED lighting and would like to know which LED lighting systems work best with this series. Important factors for me are easy installation on the shelves, good light distribution inside, color rendering, and of course compatibility with the modular design of the BESTÅ system.
I’m also interested in whether it is better to use fixed LED strips or flexible LED tape, and whether power supply via USB, power adapter, or batteries is more practical.
Additionally, it would be helpful to hear about experiences with specific brands or kits that are particularly suitable for lighting furniture and shelving. Are there any smart solutions that work well with BESTÅ?
I look forward to tips, recommendations, and also advice on potential pitfalls during installation!
Thank you in advance.
Marion
28 Feb 2020 18:47
For the BESTÅ shelves, I recommend rigid LED strips with clip mounts. They are quick to install and ideal for shelves. Flexible strips can also be used but require more effort to secure. Plug-in power supplies are more reliable than batteries, especially if the lighting will be on for extended periods.
Declan55
28 Feb 2020 19:12
Great question, the BESTÅ shelves are really fantastic furniture! 😍 I would recommend flexible LED strips because they can be adapted to all sorts of corners and edges. And if you choose smart LED options, you can control the lighting through an app, dim it, or even use multiple colors! That way, you can create a great atmosphere. Don’t be discouraged, installation is often easier than you think! Good luck!
Liduta
29 Feb 2020 08:54
Hello Jankora,
I will address your questions step by step:
- Installation: For BESTÅ, I usually recommend LED strips with a self-adhesive back. Make sure they are heat-resistant and not too thick; otherwise, they might not fit well into the rails or behind the back panel.
- Light distribution: Linear LED strips with closely spaced LEDs provide even lighting. Alternatively, you can use small individual spots if you want to create accent lighting.
- Color rendering: Choose LEDs with a CRI (Color Rendering Index) above 80, ideally 90+, to achieve the most natural color reproduction.
- Power supply: Power adapters with 12V or 24V are common. USB is convenient but has limited power output. Battery operation is only practical for smaller, infrequently used lighting.
- Smart home: Philips Hue LightStrips or similar smart strips work very well; they can be dimmed, scheduled, and integrated with voice control.
Typical mistakes include neglecting the dimensions (LED strips too long or too short) and insufficient wiring capacity.
Summary:
- flexible, self-adhesive LED strips with high CRI
- power supply with sufficient capacity
- optional smart control
- pay attention to installation dimensions
If you like, I can also share examples from my installation experience.
raelto
29 Feb 2020 10:19
For optimal LED lighting with IKEA BESTÅ shelving units, it is best to combine the following factors:
- Light source: LED strips with a linear profile are well suited due to their slim build, especially when minimal installation height is required.
- Color temperature: 3000K to 4000K for a warm, not too cold light.
- CRI: >80 for good color rendering, which is important for display compartments.
- Mounting: Adhesive tape on the back is standard; alternatively, clips or screw mounting can be used on more solid substrates.
- Power supply: Centralized with an external 12V power supply to avoid flickering and handle power surges.
- Smart control: Modules compatible with Zigbee or Z-Wave can be retrofitted.
It is also important to consider cable management to maintain aesthetics and avoid blocking any access for maintenance.
Nadine
29 Feb 2020 14:06
Hello Jankora,
About a year ago, I installed LED strips on the BESTÅ shelves from IKEA and would like to share my experience:
- I used Philips Hue LightStrip Plus because they are smart controllable and dimmable, which is especially useful for creating different lighting atmospheres.
- The installation was easy thanks to the adhesive pads; I just had to watch the length since the strips can be easily cut.
- For power supply, I used a 12V (12V) power adapter, which I hid discreetly at the back of the shelf.
It is important that the strips do not get too hot – so I recommend LEDs with low heat output. I also wired several small sections separately, which makes it very flexible.
If you have any further questions, I’m happy to help with the planning.
