Hello everyone, I am planning to use several IKEA Metod cabinets in my workshop, where the load will significantly exceed the usual kitchen cabinet requirements. Therefore, my question is: Which IKEA Metod cabinets are specifically suitable for heavy loads? By "heavy load," I mean frequent use with heavy equipment or tools weighing between 40 and 70 kg (88 and 154 lbs) per shelf, sometimes with point loads.
Do you have any experience or recommendations regarding load-bearing cabinet types, reinforcements, or special construction methods that can carry these loads over an extended period without sagging or damage? I am particularly interested in whether the carcasses or the shelves themselves are available in different versions to handle such weights.
Thank you in advance for your tips and advice!
For heavy loads on IKEA Metod cabinets, I recommend using sturdy carcasses and especially the thicker shelves (22 mm (7/8 inch)). Avoid thinner shelves, as they are more suited for regular kitchen loads. Additional metal reinforcements or cross braces can also help with larger loads.
A brief explanation: IKEA Metod cabinets are primarily designed for kitchen environments and are therefore rated for moderate loads. The shelves in the standard versions are usually 15 mm or 22 mm thick, with the 22 mm option offering higher load capacity. For loads between 40 and 70 kg (88 and 154 lbs) per shelf, you should definitely use the 22 mm shelves and position the cabinet so that the loads are well distributed.
Additionally, it is important to secure the cabinets properly: wall fastenings significantly increase overall stability. You can also reinforce the cabinet interiors with wood or metal braces to prevent sagging.
However, keep in mind that the standard shelves may be at their limit under point loads. A custom solution with additional support legs or beams might be advisable. Question: What kind of heavy appliances or tools do you plan to store? This information can help with the dimensioning.
I completely understand that you’re looking for a solution that is truly secure but also practical. That was important to me as well, so I chose the more durable Metod cabinets with 22 mm (0.87 inch) thick shelves – they really make a difference for everyday use with tools. At the same time, I fastened the cabinets to the wall in several places, which just feels safer. There’s always some uncertainty about whether the shelf will hold, but in my case, it has worked perfectly for months with tools and small machines.
If you need even more stability, I would consider adding metal braces inside. Maybe someone here has more experience with that?
JONKO schrieb:
There is always some uncertainty about whether the shelf will hold, but in my case, it has been working without issues for months with tools and small machines.That’s a good point – practical experience is very valuable. Additionally, the load-bearing capacity largely depends on whether the shelves are installed correctly and if the carcasses are aligned vertically. Even small installation mistakes can promote sagging.
BARSAN schrieb:
When it comes to heavy loads, the ultracompact shelves from Metod are better.Really? Do you mean the kitchen countertops? While these are extremely strong, they are not designed to be used as shelves – special fittings would be required for that. For standard Metod cabinets, IKEA recommends 22 mm (7/8 inch) thick shelves. Using countertops as shelves is possible, but it is more expensive and requires modifications.
In general, I recommend keeping the following points in mind:
- Use 22 mm (7/8 inch) thick shelves
- Secure the cabinets fully to the wall
- Distribute loads as evenly as possible
- Avoid point loads or support them with metal brackets
If you want, I can also provide the exact load ratings specified by IKEA and how you can increase them with reinforcements.
