ᐅ Which DIY techniques work best for IKEA Hemnes shelves?
Created on: 16 Nov 2021 08:17
Justindi
I recently purchased some IKEA Hemnes shelves and plan to customize and enhance them using DIY techniques. However, I noticed there are many different methods, ranging from paints and stains to adding moldings, applying adhesive films, or even altering the structure of the shelves. Therefore, I am curious: Which DIY techniques work best on IKEA Hemnes shelves in terms of both durability and visual effect? Are there any methods that are particularly recommended because they adhere well to the typical material of Hemnes shelves or are especially easy to implement? And what mistakes should be avoided?
I look forward to your experiences and tips!
lorena
17 Nov 2021 08:22
Just to provide some more precise advice regarding surface treatment with chalk paint and similar products:
- It is important not to completely sand down the finish or surface of the Hemnes shelves if it is still relatively intact. Instead, lightly sand and degrease.
- Chalk paint works well on solid wood, but after drying it absolutely requires a sealant to ensure water and stain resistance.
- Alternatively, a combination of wood stain and clear varnish can be used, especially if you want to preserve the wood grain.
- If you want the shelf to be more durable and less delicate, using durable acrylic paints is recommended.
A note about decorative moldings: these can be attached effectively using wood glue and small screws. Pre-drilling is advisable because Hemnes shelves are made from pine and can easily split.
If you plan to cover the shelves with adhesive films, I recommend high-quality self-adhesive films designed for furniture. The films should be applied at moderate room temperature to avoid bubbles.
If you wish, I can also provide a step-by-step guide for a specific technique once you have made a decision.
Fitigu
17 Nov 2021 09:58
A more precise guideline for preparing Hemnes shelves before painting or staining:
- Lightly sand the surface, usually with 180-grit sandpaper
- Remove dust with a damp cloth and allow it to dry thoroughly
- Use a bonding primer on highly glossy surfaces
- Applying thin layers of paint is recommended for an even finish
- Especially for solid pine wood, sealing with a thermoset resin sealant helps protect the wood fibers from moisture
These steps significantly enhance the durability of DIY coatings and prevent future chipping or wear.
Tobias
17 Nov 2021 11:11
In short: For Hemnes shelves, I recommend sanding, then applying acrylic paint and sealing with furniture wax or clear varnish. This way, you get a durable surface.
Justindi
18 Nov 2021 07:45
lorena schrieb:
If desired, I can also gladly write a step-by-step guide for a specific technique once you have made a decision.
Yes, that would actually be very helpful! I think I want to try a combination of sanding, chalk paint, and sealing. If you could write a step-by-step explanation for that, I would be very grateful. Also – how do you handle removing the old trim or the carcass on Hemnes shelves? Is there anything special to consider with Hemnes to maintain stability?
