ᐅ Which DIY projects are particularly suitable for Ikea Hemnes furniture?
Created on: 28 Jan 2021 08:44
Lolo57
I would like to start a focused discussion on the topic: Which DIY projects work especially well with Ikea Hemnes furniture?
I’m not looking for general craft ideas, but specifically for adjustments or modifications that really suit Hemnes furniture – whether due to the material structure, workmanship, or typical dimensions.
I’ve already read quite a bit about furniture upcycling, but here I want to know which DIY projects or modifications you have tried that work optimally with Hemnes furniture without compromising stability or design too much.
Practical tips on tools, materials used (e.g., paints, edge strips, screws), and whether the wood is suitable for additional cutouts or assembly work would also be interesting. Also: Are there any classic projects that just naturally work especially well with Hemnes?
Looking forward to your ideas and experiences!
Le_kin schrieb:
Could you say how extensive your DIY experience is with handling this type of furniture?Thank you for the detailed advice!
I have some basic skills and can use a cordless drill, jigsaw, and sandpaper, but I usually work on smaller furniture projects. My goal is to improve my Hemnes bookshelf by adding extra shelves and possibly integrated lighting. Therefore, I am particularly interested in whether cutting channels for cables in Hemnes furniture could be problematic or if it can simply be done.
Additionally, I would appreciate any tips on suitable LED lighting and how to install it in wooden furniture from the Hemnes series.
Lolo57 schrieb:
whether cutting grooves for cable ducts in Hemnes could cause problems, or if it can simply be done as is.In principle, there is no issue with installing cable ducts when it comes to the material – the wood density of Hemnes is well suited for such work.
However, it should be considered that Hemnes is mainly known for its solid front design and joinery. Removing too much material can weaken the structural joints or make the surface unattractive.
Therefore:
- Plan carefully before cutting, possibly using templates, to avoid damaging load-bearing areas.
- Use fine tools to minimize splintering.
- Add trims or covers to ensure the cable ducts are visually well integrated.
Another approach is to route cables along the back or underneath the furniture, if possible, to preserve the visible wooden parts.
Lolo57 schrieb:
My goal is to optimize my Hemnes bookcase with additional shelves and possibly integrated lighting.That’s a great project! To add extra shelves, I recommend using compatible metal shelf supports that fit into the pre-drilled holes. With Hemnes, these standard holes are usually spaced every 3 cm (1.2 inches), which is a plus.
For a neat finish, make sure the new shelves are made from the same material or at least have a similar thickness to maintain a consistent look.
If you plan to install LED strip lighting, pay attention to using a suitable power supply—if you’re not confident with electronics, a small 12V (12V) adapter is advisable.
Good luck with your project!
I redesigned my Hemnes bedroom wardrobe with adhesive foil – the wood was easy to sand, and the foil adhered well. If you want to add color accents, chalk paint works quite easily; the surface absorbs these paints well without much preparation.
Regarding lighting: I glued in LED spotlights that run wirelessly on batteries. This eliminates the need for channeling cables and offers great flexibility.
About cable channels: The wood is sturdy enough, but it’s important not to remove too much material, as this compromises structural strength. It’s best not to modify the back panels.
