ᐅ Which DIY methods are worth trying with IKEA Hemnes furniture?
Created on: 13 Aug 2022 09:37
Ki-aris49
I recently bought some IKEA Hemnes furniture as a base for DIY upgrades and customizations, but I’m unsure which methods are really worthwhile for this type of furniture. I’m particularly interested in durable and visually appealing modifications that maintain or even enhance the character of the Hemnes series.
Which techniques have worked well for you, for example in changing the surfaces, adding extra elements, or improving stability?
Are there alternative material combinations or special tools that you would recommend? I look forward to detailed experiences and tips on how to best personalize Hemnes furniture, which is mostly made from pine wood.
teyosef
14 Aug 2022 13:09
For sealing in a children’s room, water-based, low-odor clear coats based on polyurethane are especially suitable. They have low emissions and still create a very durable surface.
I always recommend a light sanding between each coat to improve adhesion of the next layer.
Tool tips for beginners:
- Random orbital sander with variable speed (not set too coarse!) for quick and even sanding
- Brushes and small foam rollers for applying the finish, as they leave minimal visible brush marks
- Small files or sanding sponges are helpful for edges
It is also important not to apply too much pressure when sanding to avoid damaging the material.
For installing handles and fittings, a drilling template (or a homemade jig) is recommended to ensure the holes are evenly spaced.
Danial
15 Aug 2022 07:36
If we focus the discussion on practical benefits, I wonder if the modification of IKEA furniture like Hemnes is more symptomatic of the modern do-it-yourself trend, which tends to replace the purchase of well-built, high-quality furniture.
Lamar schrieb:
I also wonder if the effort is really worth it, considering how much time and material goes into it.
I can only agree with that – many people invest time without realistically comparing it to a piece made by a carpenter or a custom-made item.
Still, there is a different kind of value when you work on the furniture yourself and customize its appearance. It is less about increasing monetary value and more about personal identification and individuality.
Regarding stabilization: There are indeed limits since Hemnes is mainly made of pine and veneered panels. Anyone expecting more durability should consider that when purchasing sturdier furniture, not try to fix it later.
In conclusion: Anyone taking the DIY approach should set realistic expectations about materials and durability; otherwise, it only leads to frustration.
