I am currently looking into choosing BILLY shelves and trying to determine which of the available finishes is the most durable, especially regarding scratches, wear from frequent use, and UV resistance. I am interested in the differences between classic colors like white, birch, or oak, as well as special variants that might be more robust. How do the finish or surface really hold up under everyday stress? I have found some general information, but concrete experiences or well-researched assessments would be very helpful for me. Thanks in advance!
Hey, great question! 😊 I’ve gathered some experience with this and can say that white on BILLY shelves tends to show small scratches more quickly, especially if the shelf is used often or items are moved around frequently. It’s quite noticeable! Birch and oak, on the other hand, are more durable because the surface texture has more irregularities and natural patterns that help conceal wear and tear.
Oak in particular looks generally more robust and also handles UV exposure (that is, sunlight) better, so the color doesn’t fade as quickly – which is great if the shelf is near a window.
In summary: If you want a look that lasts as long as possible, I’d recommend birch or oak. White looks very clean but can sometimes show weaknesses, especially with heavy use ;-) Good luck with your decision!
Regarding the most durable color for BILLY shelves, it is important to consider that the type of surface coating and the material used matter more than the color itself.
The standard versions of BILLY shelves have a melamine resin coating, which is relatively scratch-resistant. However, white painted shelves tend to show signs of wear more clearly, as scratches or scuffs are more noticeable on light, smooth surfaces than on wood grain or textured finishes.
Birch and oak textured finishes benefit from a nuanced grain pattern that helps conceal minor damage. UV resistance in furniture of this price range is generally moderate — prolonged exposure to strong sunlight can cause slight discoloration, which tends to be more noticeable on darker tones.
Therefore, choosing textured finishes is recommended, as they make wear less visible and help maintain a uniform appearance over time.
If the shelf is subject to heavy use, a protective film or cover is advisable regardless of the color.
Z
zarHenning7 Apr 2023 09:25parnar schrieb:
White on BILLY shelves unfortunately tends to show small scratches more quicklyThat sums it up well. Additionally, oak is generally more durable than birch.
So, if you prioritize durability, I recommend an oak finish.
White looks nice, but it is not the most resilient option.
