ᐅ Which care products provide the best protection for Ikea Hemnes wood?
Created on: 26 Aug 2024 09:13
litefa
Hello everyone, I recently bought an IKEA Hemnes piece of furniture made of pine wood and want to take the best possible care of it so that the surface stays beautiful for a long time and the wood does not get damaged. I am particularly interested in which care products are best suited to protect the surface, repel moisture, and minimize typical signs of wear such as scratches or discoloration. What experiences have you had with oils, waxes, or special wood care products for Hemnes furniture? Are there any brands or ingredients that you would especially recommend, and how often should maintenance ideally be done? I look forward to detailed responses so I can treat my furniture in the best way.
litefa
27 Aug 2024 12:47
benon schrieb:
Hemnes furniture is already lightly pretreated
That’s interesting information I hadn’t considered before. Does this mean the furniture might come with a certain level of sealing that could make oil-based maintenance more difficult?
Are there any experiences on how long to wait after purchase before starting to oil or wax the piece? I want to avoid compromising the protection by treating it too early and instead aim to enhance it. Maybe someone here has advice on the best way to do the initial care for Hemnes and how to tell if the wood still has a factory-applied layer or if it’s ready to absorb care products?
Lorukeo
27 Aug 2024 14:33
litefa schrieb:
Are there any experiences on how long to let the piece of furniture rest after purchase before applying oils or waxes?
Hemnes furniture elements usually come with a thin lacquer or surface treatment that seals the wood for protection. In this case, applying oils or waxes initially is not effective because the sealing closes off the surface. Therefore:
- Check the surface: If it feels smooth and slightly glossy, a lacquer film is likely present.
- In this case, light sanding or abrasion with fine sandpaper helps to remove the seal if you prefer an oil or wax treatment.
- Waiting time after sanding: Let it rest for at least 24 hours, remove dust, then apply oils or waxes.
If the surface is open and matte, you can start caring for it immediately. In this case, "resting" in the traditional sense is not necessary, but rather checking and preparing by sanding if needed. This ensures the treatment is lasting and effective.
pikin
28 Aug 2024 07:14
In summary, for the best possible protection of IKEA Hemnes wood, the following approach is recommended:
- First, check whether the wood is pre-sealed (typically a slightly glossy surface).
- If so, lightly sand with fine sandpaper to remove the lacquer film.
- Thoroughly remove all dust from the surface.
- Use a natural wood oil (such as linseed oil or tung oil) to nourish the wood and protect it against moisture.
- If needed, apply a thin layer of furniture wax after oiling to provide additional protection against scratches and stains.
- Repeat the treatment regularly, approximately every 6 to 12 months, depending on frequency of use.
This preserves the natural appearance, improves durability, and maintains the pleasant feel of Hemnes pine wood.
