ᐅ Which BILLY models are especially sturdy for heavy books?
Created on: 17 Nov 2023 08:37
Karltau1
Karltau1
17 Nov 2023 08:37
I am planning to purchase several BILLY shelves from IKEA for my extensive book collection. Since many of the heavy reference books often weigh over 3 kg (6.6 lbs) per book, I want to make sure I choose a model that truly stands out in terms of stability and load capacity.
Therefore, my specific question is: Which BILLY models, for example those with additional reinforcements or special materials, are especially suitable for holding heavy books long-term without the shelves bending or the overall construction becoming unstable?
I look forward to hearing about your experiences, recommendations, and any tips on alternative options that IKEA offers within the BILLY range, so I can make an informed decision.
FAVALERIE9
17 Nov 2023 09:22
Hello Karltau1,
if you want to store heavy books, I recommend the BILLY shelves with a middle panel. These are more stable and prevent the shelves from sagging. Additionally, you can always secure the shelves with extra metal supports.
The classic BILLY models are made with chipboard panels but are suitable for heavy loads with these reinforcements.
LOGEMIN
17 Nov 2023 14:05
to answer Karltau1’s question in detail: The classic BILLY series from IKEA is made of particleboard with a melamine foil finish, which is perfectly adequate for regular books but can quickly reach its limits with heavy technical books.
1. BILLY with center panel: As FAVALERIE9 already mentioned, the center panel provides a more stable overall structure by preventing lateral bending and better distributing the load. For heavy books, this is basically essential.
2. Additional shelves: IKEA offers stronger shelves available in the same design but with reinforced support structures made of metal. Anyone wanting to store many heavy books should consider these replacement shelves.
3. Greater depth: Models with a depth of 40 cm (16 inches) offer more stability than the narrower 28 cm (11 inches) versions, as they are less prone to sagging.
4. Fixing: Especially for tall shelves, wall mounting is extremely important to prevent tipping or bending.
In summary, a combination of center panels, deeper models, and reinforced shelves should be chosen to ensure maximum stability. In some cases, one might also consider whether the BILLY Vittsjo or other shelving series with metal frames could be an alternative for particularly heavy loads.
kasan
18 Nov 2023 11:13
LOGEMIN schrieb:
A combination of back panels, deeper shelf units, and reinforced shelves should be chosen to ensure maximum stability.
This is certainly a very good approach; however, I think it’s important to carefully check the total load capacity per shelf when selecting. IKEA usually specifies a maximum load of about 30 kg per shelf, depending on the width and depth.
FAVALERIE9 schrieb:
always secure the shelves with additional metal supports
It would be helpful to know whether these are official IKEA accessories or if metal profiles are being added independently, as this makes a difference in handling and stability.
It is also important to distribute the weight as evenly as possible when storing heavy books; otherwise, localized bending can occur even with reinforcement.
Furthermore, for extreme loads, it’s advisable to consider alternative furniture – since BILLY is basically not designed as a heavy-duty shelf. So, it’s important not to focus solely on looks and price but also on durability and safety.
Do others have any practical experience with actual load capacities in use?
