ᐅ What type of screws are used in IKEA Brimnes models?
Created on: 23 Jun 2020 18:47
Johnny55
Johnny55
23 Jun 2020 18:47
I am currently assembling the IKEA Brimnes furniture series and have noticed that I cannot find clear information about the exact type of screws IKEA uses for this model.
My question is: What type of screws does IKEA use specifically for the Brimnes models, especially for the cabinets and dressers?
I would like to understand whether these are general-purpose screws, special connector fittings, or even dowel pins. Information about size, thread type, or material would also be very helpful.
Does anyone have experience with this furniture and can provide details or tips about the screws included in the package or which ones are best to buy as replacements if needed?
Thanks in advance for your support!
mabla
23 Jun 2020 19:12
Johnny55 schrieb:
My question is: What exact type of screws does IKEA use for the Brimnes models?
The Brimnes furniture typically uses standard chipboard screws with coarse threads, approximately 4x50 mm (4x2 inches), as well as cylinder head screws for connector fittings. You can get replacements at IKEA or at a hardware store.
sarlo
24 Jun 2020 07:33
Johnny55 schrieb:
Which type of screws does IKEA use in the Brimnes models exactly, especially for the cabinets and dressers?
Hello!
IKEA mainly uses screws specifically designed for engineered wood materials like particleboard in the Brimnes models. These are usually coarse-thread particleboard screws that provide a secure connection and prevent pull-out. In addition to standard wood dowel screws, you’ll often find cylindrical head screws with internal hex drives (Allen screws) used to connect metal fittings.
Here is a brief overview:
- Particleboard screws approximately 4x50 mm (4x2 inches) for frame assembly
- Cylindrical head screws M6x30-40 mm (M6x1.2-1.6 inches) for fittings
- Wood connectors with threaded rods and dowels
The material is usually zinc-plated to prevent rust. If you need replacements or more precise information, it’s best to refer to the assembly instructions for the specific Brimnes model; these typically include diagrams and dimensions of the screws.
Hope this helps!
kibutar
24 Jun 2020 15:47
Johnny55 schrieb:
My question is: What exact type of screws does IKEA use for the Brimnes models, especially for the wardrobes and dressers?
The topic of screws used in IKEA Brimnes furniture is actually a bit more complex, as different types of screws are combined to keep the furniture stable.
Here is a detailed breakdown:
- Chipboard screws: Usually 4 mm in diameter, about 40–50 mm (1.5–2 inches) long, with coarse threads for secure grip in chipboard panels. These are mainly used to fasten the carcass and back panels.
- Cylinder head screws with internal hex socket M6: Used to connect fittings such as angle brackets or connector bolts that stabilize the furniture frame.
- Connector bolts (cam lock pins) and cam nuts (cam connectors): These specialized furniture connectors are typical for IKEA products, used to lock components together and enable professional assembly without changing tools.
- Wooden dowels made from stained pressed wood: Complement screws and screw connections to provide lateral stability.
It is important to know that IKEA often uses high-quality galvanized steel screws in the Brimnes series, which are protected against corrosion. Also, the compatibility of screws with the chipboard used is essential to avoid cracking or pull-out under stress.
If you are looking for replacements, pay particular attention to the thread pitch on chipboard screws to ensure they don’t fit too loosely. Generally, IKEA’s hex socket screws are M6x30 mm (1.2 inches) and chipboard screws are 4x50 mm (1.5–2 inches) standard.
I am also happy to help with questions about a specific piece of furniture if it concerns a particular wardrobe or dresser from the Brimnes range.
PERON
24 Jun 2020 18:29
sarlo schrieb:
IKEA mainly uses screws designed specifically for engineered wood materials like particleboard in the Brimnes models.
Exactly!
You could almost say these screws are the unsung heroes holding the entire Brimnes series together. 😄 The combination of particleboard screws and the popular IKEA cam locks makes assembly both straightforward and sturdy.
When assembling my Brimnes dresser, I always made sure not to overtighten the screws, as this can unnecessarily damage the wood. A trick that shouldn’t be underestimated!
If anyone needs replacements: IKEA usually offers matching spare sets containing the same screw types. And if the screws get lost, your local hardware store is a good option—many standard sizes are compatible.
So, don’t underestimate those small, unassuming screws—they really matter! 😉
