ᐅ What tips are helpful for adjusting Ikea Metod cabinet doors?
Created on: 24 May 2022 09:37
Puneo
Puneo
24 May 2022 09:37
I recently installed some Ikea Metod cabinet doors and am now facing the challenge of adjusting them properly. I noticed that the doors don’t always close evenly and sometimes hang either too high or too low. I have already adjusted the screws on the hinges slightly but am unsure how to proceed systematically to achieve even and flush closing without damaging the door or the cabinet.
Does anyone have practical tips or experience that could help with correctly aligning the doors? Advice on small adjustment steps as well as dealing with issues like uneven walls or irregular gaps between the doors would be very helpful.
Thank you in advance!
Espen
24 May 2022 10:09
The Metod hinges have three adjustment screws: one for depth, one for height, and one for lateral alignment.
You should start by adjusting the height, followed by the lateral alignment, and finally the depth.
This ensures precise door alignment.
RENMA
24 May 2022 12:18
For precise adjustment of Ikea Metod cabinet doors, I recommend a systematic approach:
- Start by aligning the door vertically (height adjustment at the hinges) to ensure the door is neither too high nor too low.
- Next, adjust the door sideways so that the gap between the doors or to the adjacent surface is even. This adjustment is made using the lateral adjustment screw on the hinge.
- Finally, adjust the door’s depth so it sits flush with the cabinet frame.
It is important not to overload the cabinet’s wooden panel—excessive screw turning can damage the threads. Use a good screwdriver with the appropriate blade to turn the screws precisely.
If walls or floors are uneven, it is advisable to first ensure the cabinet frame is correctly positioned, as the doors can only be properly adjusted if the cabinet itself is level.
Marlenepa
25 May 2022 08:42
Hello Puneo,
I have often noticed during the adjustment of Metod cabinet doors that fine-tuning between the individual hinges pays off. Each door is attached with two hinges, and it often helps to:
- Adjust the height of the upper hinge to align the door horizontally.
- Then slightly fine-tune the lower hinge to ensure the door lightly presses against the cabinet frame.
Also, make sure the screws on the hinges are not tightened too much before all adjustments are completed – this allows easier readjustment.
If the gaps are uneven, you can carefully adjust the lateral adjustment screw on one hinge at a time until the gap is even.
Lastly, a small tip: sometimes the hinges are pre-tensioned from the factory, which can make adjustment more difficult. Also check if the door drags in certain areas – if so, slightly adjust the depth.
I hope this helps!
ANMARCOS
26 May 2022 15:53
I have to admit, I sometimes find all the adjustments needed for Ikea Metod doors a bit overrated.
RENMA schrieb:
If walls or floors are uneven, it is advisable to first ensure the correct position of the cabinet carcass, as the doors can only be properly adjusted if the carcass itself is level.
That’s the key point. Those who spend a lot of time adjusting the doors often overlook that the basic frame isn’t actually straight. Of course, under those conditions, extensive adjusting becomes a never-ending task.
My advice is: first check the carcass, level it if necessary using wedges or shims, then adjust the doors. This is the only way to achieve a satisfactory long-term result. The screws on the hinge do not change crooked walls or floors.
Also: expectations that all doors will always close perfectly flush come from wishful thinking. In reality, standard doesn’t always mean perfect.
