ᐅ What dimensions should my T30 structural load-bearing wall have?
Created on: 3 Sep 2019 20:48
immermehr
we had our planning meeting today and I need to clarify a question.
It concerns a T30 door:
- According to the Novoferm datasheet: structural dimension: 100x2125mm (4x83.7 inches), rough opening/nominal size: 1010x2130mm (39.8x83.9 inches), clear opening: 932x2091mm (36.7x82.3 inches), frame outer dimension: 1042x2159mm (41x85 inches) with a 25mm (1 inch) floor recess.
- We have a screed plus tiles layer of 18mm (0.7 inches).
Can someone tell me which size I need for my rough masonry opening?
Thanks in advance for your help.
Scout
4 Sep 2019 16:21
Your screed (not to be confused with a dining table) is more than 18 mm (0.7 inches) thick. Definitely. Especially with tiles. Even the thinnest possible one (poured asphalt screed) needs to be at least 25 mm (1 inch)!
That’s 18 cm (7 inches) in total (16.5 cm (6.5 inches) plus 15 mm (0.6 inches) for tiles and adhesive) from the raw floor level, with 5 or 6 cm (2 to 2.4 inches) of screed and the rest being insulation.
Otherwise, just leave it to the architect—that’s what you have one for. If it starts like this, you might easily have a heart attack during the construction process ops: ops:
immermehr
5 Sep 2019 21:02
Scout schrieb:
Your screed (not dining table) is definitely more than 18 mm. Especially with tiles. Even the thinnest possible (flowing asphalt screed) must be at least 25 mm!
That is 18 cm (16.5 cm plus 15 mm (about 0.6 inches) tiles and adhesive) from the raw floor, including 5 or 6 cm (about 2 to 2.4 inches) screed, the rest insulation.
Otherwise, just leave that to the architect—that’s what they’re for. If it starts like this, you might still get a heart attack during construction ops: ops:
Hi Scout,
Thanks for your reply.
Dining table was an autocorrect mistake. My phone does not know the word screed :d
And you are right. My screed is more than 18 mm. It is a total of 18 cm (as you wrote).
I wasn’t completely satisfied with my architect. We are “unfortunately” building with a general contractor. The architectural service is included in the package. I initially decided on self-performance for about 1000€ difference from the T30. I didn’t anticipate the consequences.
