ᐅ What should I do if the Billy bookcase is shaky and unstable?
Created on: 4 Apr 2018 08:13
PRAMEO
I recently assembled a Billy shelf from Ikea, but it feels quite wobbly and overall not very stable. This issue mainly occurs when the shelf is loaded with heavier items or when it is touched lightly. Although the back panel appears to be installed, the shelf still moves noticeably, which worries me, especially regarding safety with small children in the home.
I’m interested in any options to make the shelf more stable without having to completely disassemble it or buy a new one. Are there any special tips for reinforcement, tightening, or other advice you could recommend?
Perhaps someone has experience with similar problems with Billy shelves or comparable models. Thanks in advance to everyone who can help!
reni45
5 Apr 2018 08:50
Stabilizing the shelf unit:
- Nail the back panel securely
- Make sure the shelf is level
- Tighten the screws
- Fix it to the wall
That’s all it takes.
PIDAN
5 Apr 2018 11:11
Additional information for everyone:
The Billy shelf unit is primarily stabilized by the back panel, as it mainly absorbs the shear forces. Therefore, it is essential that the back panel sits flush, is fully nailed or screwed in, and has not been damaged.
If the shelf wobbles, often the feet are not evenly standing on the floor, or the back panel is not fully seated. The floor should be checked with a spirit level, and uneven areas should be compensated if necessary (e.g., with rubber or felt pads).
Furthermore, the following applies: Single-wall furniture of this type is generally less stable without wall mounting; therefore, the IKEA wall brackets are always recommended, especially for larger or taller units.
If this is not possible due to the wall structure, additional brackets or metal reinforcements can be installed at the bottom of the shelf, but this is usually a solution for DIY enthusiasts.
The tips regarding tightening screws and correctly nailing the back panel are accurate. The nails should be driven in straight and fully to prevent slipping.
Ryker66
6 Apr 2018 09:03
PIDAN schrieb:
The Billy shelf is primarily stabilized by the back panel
In my experience, the stability mainly depends on how the back panel is attached and on sealing the feet.
Especially on hardwood floors, there are often slight unevenness. Small plastic or rubber feet help in such cases, not felt pads.
If the shelf still wobbles despite all measures, you should definitely consider wall mounting. Investing in brackets is worthwhile and significantly improves safety.
