ᐅ What kind of moisture damage have you experienced with the Kallax?
Created on: 20 Jan 2021 08:37
tayfun_bla
tayfun_bla
20 Jan 2021 08:37
I recently discovered moisture damage on a used Kallax shelf and I’m wondering how common this problem is. Specifically, I am interested in what types of moisture damage you have experienced with your Kallax furniture, how you noticed it, and if there are particular areas of the shelf that are especially prone to damage. For example, have you seen visible discoloration, swelling, warping of the particleboard, or even mold growth? I would also like to know if you took any immediate actions, such as drying or sealing, and how effective those measures were. Thanks in advance for sharing your experiences!
le_jan
20 Jan 2021 09:15
For me, moisture usually appeared at the lower edges, especially when the floor was slightly damp. I never noticed any discoloration, but the panels did swell slightly. Important: Do not place the shelving directly on the floor, this helps.
Domau0
20 Jan 2021 11:42
le_jan schrieb:
Don't place the shelf directly on the floor; that helps.
This is a very important point. Although the Kallax particleboard is resistant due to the melamine coating, it is not waterproof. If moisture comes from below, it can penetrate the cut edges, especially if the material at the bottom is not protected.
I once had a case where a leaking water pipe in the bedroom caused moisture to rise through the laminate flooring over several weeks. The cross-sections of the bottom shelves showed clear swelling — the top layer lifted off, and the tension in the material led to small cracks along the edges.
Measures? I first removed the shelf and let it dry completely in a dry place, then sealed all the cut edges multiple times with clear varnish. It’s also important to eliminate the source of moisture; otherwise, any repair is pointless.
Can you say how long your Kallax was exposed to such conditions?
tayfun_bla
20 Jan 2021 13:08
Thank you for the detailed response! The shelf was likely in a room with high humidity for several months, sometimes near an exterior wall that got quite cold in winter. I noticed slight discoloration on the cut edges at the bottom, but no cracks or significant swelling yet. To me, this sounds like an early stage.
How would you specifically proceed to prevent further damage? Is sealing sufficient, or would it be better to consider replacing the affected parts right away? And do you have any advice on how to measure moisture in case there might still be invisible damage?
angel
21 Jan 2021 07:27
Hello!
I would like to point out that the moisture damage on the Kallax mainly results from a combination of poor air circulation and direct contact with water.
A moisture meter designed specifically for wood or chipboard can help identify the problem areas. You can use it to check critical spots, especially the bottom edges or areas that might be in contact with damp walls.
To protect the furniture, I recommend always keeping it off the floor, ideally on small plastic feet or furniture legs with spacers — this allows better air circulation and helps moisture escape.
Sealants such as varnishes are effective, but only if the moisture hasn’t already penetrated deeply. If there is severe swelling, it’s often best to replace the affected chipboard parts, as their stability and function are otherwise compromised.
What is your room’s usual humidity level? Do you have a hygrometer?
tayfun_bla
22 Jan 2021 16:52
angel schrieb:
Sealing with varnishes is effective, but only helpful if moisture has not already penetrated deeply.
Thank you for the tips! I now have a hygrometer, and the humidity in the room is usually around 60-65%, which is quite high.
I will probably place the shelf on furniture feet and carefully seal the cut edges with a sealing varnish. If I do notice any mold or significant swelling soon, I would consider replacing it. Given the price of the Kallax, sometimes replacement is the better choice when the damage is too severe.
If anyone has recommendations on what type of varnish is best for sealing particleboard, I would appreciate it! 🙂
