ᐅ What impact does incorrect installation have on the stability of MALM?
Created on: 2 Aug 2024 08:14
Jay35
Hello community, I am currently looking into the question: What impact does incorrect assembly have on the stability of the Malm shelf from IKEA? Especially with furniture like this, which is generally quite sturdy, I wonder how much influence small assembly mistakes can have—whether it’s attaching the connectors incorrectly, using the wrong screws, or misalignment. Who has practical experience or knows the technical reasons why faulty assembly could significantly affect stability? I am particularly interested in whether the shelf becomes noticeably more prone to damage or if minor deviations are generally negligible in everyday use. Thanks in advance for your insights!
Nathanaelk schrieb:
Have you noticed any recurring issues during your assembly or do you have concerns about any components possibly being installed incorrectly?Good question. I had the impression that the side panels were not always screwed in at a perfect right angle. Also, the nail on the back panel might not be completely flush. Some of the screws were also a bit loose – I didn’t overtighten them, but maybe I didn’t apply enough force.
LOGEMIN schrieb:
If you want, I can give you some specific tips on how to identify and fix mistakes.I’d really appreciate that! It would help me a lot because I want to be as sure as possible that the shelf will hold up well over time without problems.
Hello Jay35, I am happy to help you with the inspection. First, you should use a spirit level to check if all sides are perfectly perpendicular.
Then check if all the screws are fully tightened and secure – especially those that connect the side panels to the back panel.
This can be critical because a slight misalignment shifts the loads and causes the supporting structure to bend. Finally, I recommend securing the back panel multiple times – it is essential for the overall stability of the entire shelving unit.
Jay35 schrieb:
I had the impression that when screwing the side panels, the right angle was not always precisely observed.
I completely understand the concerns about stability – I once had a wobbly MALM shelf myself and was unsure at first whether I could fix it or needed to order a new one. In the end, it was simply an assembly issue that could be resolved by readjusting the screws.
The question of whether incorrect assembly can cause long-term damage is important, as furniture is often discarded even though repairs might be possible. Stay calm and take your time with each step when fixing it.
Nathanaelk3 Aug 2024 09:48Jensson schrieb:
First, you should use a spirit level to check that all sides are perfectly square.
Then check whether all screws are fully inserted and tight.Exactly, and I also recommend paying special attention to the type of screws used in MALM. Some screws have a special coating designed for particleboard, which provides a stronger hold. Using the wrong screws can weaken the stability, even if everything looks fine visually.
Additionally, it’s worth replacing the nails on the back panel with screws, as screws offer better grip and help stabilize the structure.
Has anyone here ever reinforced the back panel to improve stability?
Nathanaelk schrieb:
Some have a special coating for particle boards.Exactly right. This is a common mistake that is often overlooked. If you use regular screws, the connections tend to loosen sooner.
