ᐅ What can be done about a loose back panel in BILLY bookcases?
Created on: 21 Jul 2020 10:03
julurjan
Hello everyone, I have a problem with my Billy bookshelf where the back panel is very loose, which reduces the stability of the shelf. The back panel is only held in place by small nails on the sides, which loosen over time and no longer grip firmly in the wood. Does anyone have tips or tried-and-true solutions for securing the back panel better without having to completely disassemble the shelf? It would also be helpful if you have experience with different materials or methods that provide a long-lasting hold and make the shelf more stable. Thanks in advance!
praWarre69
21 Jul 2020 14:35
I reinforced my Billy with small corner brackets on the inside – not the most elegant solution, but rock solid! 🙂 Just a few screws, and the back panel holds like new. I also glued the corners with assembly adhesive for extra strength. It works great, and you can hardly see anything from the outside.
Ritaba
21 Jul 2020 15:12
I would recommend using screws that are not too thick, preferably with a countersunk head. This way, they won’t push the back panel apart too much and will sit flush. Pre-drilling is essential, otherwise the wood will split.
julurjan
22 Jul 2020 09:47
BOSULE schrieb:
gluing thin strips of plywood or MDF along the rear edges between the back panel and the shelf
That seems like a reasonable reinforcement. What thickness should the strips be roughly? And what is the ideal length? Should they cover the entire shelf height or just certain sections?
praWarre69 schrieb:
used small furniture brackets inside for support
Is it still easy to remove the brackets later if the back panel needs to be replaced?
I’m considering using a combination of methods, but I’m a bit concerned about plywood strips since the material can warp with moisture.
cecile65
22 Jul 2020 11:01
For the back panel, I used thinner hardwood strips, 5mm (0.2 inches) thick and about 10cm (4 inches) long, which I glued in several places on the inside. This keeps the back panel stable and helps distribute the load on the shelf more evenly.
BeAndrea
22 Jul 2020 12:46
julurjan schrieb:
Assembly adhesive sounds interesting, do you have a specific recommendation?
Yes, I often use Pattex assembly adhesive or a similar solvent-free adhesive. It has relatively strong initial tack and absorbs vibrations well. It’s important that the back panel is clean and dry before gluing, otherwise the bond won’t hold well.
julurjan schrieb:
Concerned about plywood strips because of moisture
If the shelf isn’t in a very humid room, plywood or MDF shouldn’t cause any problems. Otherwise, hardwood strips are more reliable. You can also seal the edges with clear varnish.
EDWARD0
22 Jul 2020 14:03
One more tip: If the back panel starts to come loose permanently, you might consider using a thin plywood sheet as a new back panel. It is more stable than MDF and easier to fasten. Just cut it to size and reattach.
