ᐅ What are some DIY ideas to update or customize Ikea HEMNES furniture?
Created on: 25 Nov 2020 08:37
LulikeHello everyone, I’m currently thinking about how to personalize and enhance my Ikea Hemnes furniture without completely changing the basic structure or doing too much work. I’m mainly interested in practical and creative DIY ideas that can be done with limited tools, such as new handles, surface treatments, or small visual adjustments. I like the series itself, but it can look a bit too “standard” in many homes, and I would like to know what options are available to spruce up HEMNES furniture without making it too expensive or compromising stability. Does anyone have specific tips or experiences on how to upgrade these pieces? For example, interesting paint finishes, special techniques for wood stains, or creative handle alternatives? I’m open to all ideas, even if they are unconventional. Thanks in advance!
To effectively enhance HEMNES furniture, I recommend a systematic approach that even beginners can successfully follow. Here is a three-step suggestion:
- First: Prepare the surfaces. HEMNES pieces are usually made of solid or veneered pine wood protected with clear lacquer. Carefully remove this coating using fine sandpaper (220 grit) and then thoroughly clean the surfaces.
- Second: Change the appearance by painting or staining. A wood stain in a darker tone (walnut or light oak) can highlight the natural grain and give the furniture a more premium look. Alternatively, a chalkboard or chalk paint works well if you want a matte finish.
- Third: Replace or customize the handles. Often, the standard handles are the smallest but most noticeable element that adds individuality. I recommend brass handles or colored ceramic handles for a vintage charm. Alternatively, you can sand old handles and repaint them.
Common mistakes: Insufficient sanding before painting results in poor adhesion. Also, always apply sufficiently thin layers to avoid drips. It’s best to lightly sand between coats.
Summary: Prepare the surfaces properly, then change the look with stain or paint, and finally personalize with attractive handles. This way, stability and functionality are maintained, while the appearance is significantly improved.
LOJOPAR schrieb:
Prepare the surfaces well, then change the appearance with stain or paint, and finally personalize it with attractive handles.That sounds nice, but honestly: Is it really more than just a bit of paint and new knobs? This "upgrade" doesn’t turn an IKEA piece into a designer chair. I think many people overestimate these DIY projects. You swap a few handles, paint a little, and believe you’ve made a significant change. In the end, it’s still a mass-produced product.
Why not just buy something unique instead of putting in the effort? Or is the real value in the act of making it yourself, regardless of the result? My theory is that many DIY ideas involving IKEA furniture come from a mix of boredom and the desire for personalization—but the outcome usually isn’t a lasting design solution.
