I’m interested in knowing which ceiling height you have chosen or are likely to choose.
Are you satisfied with your choice? Looking back, would you choose a different ceiling height? If yes, why?
Ddorfer
P.S. For the survey, please select the ceiling height that is closest to yours.
Ddorfer
We really stand out from the norm: we have an open wooden beam ceiling, and the clear height up to the bottom of the beams is 2.42 m (7 ft 11 in) including the floor covering. The beams themselves are 22 cm (8.7 in) high. Due to the eave height requirements in the development plan, we made a compromise between a lower ceiling height and knee walls on the upper floor. But since our apartment back then only had 2.37 m (7 ft 9 in) height, it works for us.
On the upper floor, we don’t have an attic peak; instead, we have an open beam ceiling all the way up to the ridge beam at 3.8 m (12 ft 6 in).
Otus11 schrieb:
For our dimensions of 13.99 m x 9.24 m (46 ft x 30 ft), the additional cost for increasing the ground floor ceiling height to 2.875 m (9 ft 5 in) clear structural height (top of foundation slab to underside of ceiling. Later around 2.65+ m (8 ft 8 in) room height. Including brick veneer, excluding door and window changes): 3,960.17 EUR. I need to revisit this thread.
May I ask what ceiling height you have inside your homes?
Baufie schrieb:
May I ask what ceiling heights you have for your interior spaces?Measured from the finished floor surface.
Ground floor: 2.71 m (target: 2.70 m)
Upper floor: 2.66 m (target: 2.65 m)
I happened to measure recently with a laser.
Sebastian7924 Aug 2016 21:50Then measure at several points – you will usually find some variations.
Sebastian79 schrieb:
Then measure at several points – you’ll usually find differences True. You will surely believe me (considering my profession) that I did that. The variation is less than or equal to 0.5 cm (0.2 inches).
Let’s see what the coming years will bring... laugh. Bent back, ceilings higher and lower.
Baufie schrieb:
I need to revive this thread again.
May I ask, what height do your door frames have? Sorry, the spell-checker played a trick on me.
I wanted to know what height your doors have with room heights between 2.60 and 2.70 meters (8 ft 6 in to 8 ft 10 in).
