ᐅ What ceiling height did you choose?
Created on: 6 Mar 2016 00:40
Ddorfer
I’m interested in knowing which ceiling height you have chosen or are likely to choose.
Are you satisfied with your choice? Looking back, would you choose a different ceiling height? If yes, why?
Ddorfer
P.S. For the survey, please select the ceiling height that is closest to yours.
Piotr1981
12 Jul 2020 23:12
Sebastian79 schrieb:
So, here are a few pictures.
Hope this helps you.
[ATTACH alt="fenster-bruestungshoehe-Tür-Küche-wandhoehe-151723-1.jpg"]10746[/ATTACH] [ATTACH alt="fenster-bruestungshoehe-Tür-Küche-wandhoehe-151723-2.jpg"]10747[/ATTACH] [ATTACH alt="fenster-bruestungshoehe-Tür-Küche-wandhoehe-151723-3.jpg"]10748[/ATTACH] [ATTACH alt="fenster-bruestungshoehe-Tür-Küche-wandhoehe-151723-4.jpg"]10749[/ATTACH] [ATTACH alt="fenster-bruestungshoehe-Tür-Küche-wandhoehe-151723-5.jpg"]10750[/ATTACH]
Could you please tell me again how high your ceiling is? And the height of the windows?
We are planning a clear room height of 2.72m (8 ft 11 in).
Floor-to-ceiling double doors are 2.25m (7 ft 5 in) high,
plus the box for the external venetian blinds. Does that work?
Piotr1981
12 Jul 2020 23:13
bluminger schrieb:
This thread made us realize that the planned ceiling height for the large kitchen/dining/living area might be a bit low. So far, we planned about 2.625 m (8 ft 7 in) wall height, which equals about 2.45 m (8 ft 0 in) clear room height. Now we would like to build half a brick higher, so approximately 2.75 m (9 ft 0 in) wall height and about 2.57 m (8 ft 5 in) clear room height. We hope that this change is still possible after the building permit / planning permission has been granted.
Now to the actual question: which door and window heights would you recommend? We would like the floor-to-ceiling windows in the kitchen/dining/living area to be as tall as possible. Above these, there will be the roller shutter box, and from the available height, about 5 cm (2 inches) need to be deducted for insulation under the terrace roof.
We are planning to consult a window manufacturer soon, but independent preliminary information would, of course, be helpful.
This also interests me.
Piotr1981
12 Jul 2020 23:24
Jochen104 schrieb:
You also need to consider the lintel and, depending on the floor, possibly the ring beam.
Our non-floor-to-ceiling windows are just under 80cm (31 inches) high. We preferred this look since some of these windows are also continuously 2 meters (79 inches) wide.
Otherwise, I would have chosen a height of about 1–1.10m (39–43 inches).
Hi Jochen,
do you happen to have a photo of this?
We are facing the same decision. Room height (clear height) is 2.72m (9 feet), window width 2 meters (79 inches), sill height 88.5cm (35 inches).
How would an 80cm (31 inches) height feel in practice? Is there enough space below the window?
Thanks and best regards
